VarelaAdam1923
New Member
Good evening y'all, I have this Chrysler 8 3/4 I have for my tea bucket I took it apart because I thought it was just the passenger side inner seal that was leaking. But when I took it off the bearing that goes around the shaft was loose and the inside of the housing was all fucked up. The pictures that show fluid leaking out is the passenger side and then the side that has none is the driver side. My question to you guys is this rear end fucked and if anybody else had this issue. I don't know s*** about this stuff when it comes to the rear ends and just hoping to get some knowledge from y'all. Also the inner seals were different colors I don't know if that makes any difference but I know the difference between a two-piece seal and a one-piece of course.
