[Found!] 1/4" square head bolt from early A steering column
Bob Jasinski
Danville CA
I lost one (of two) steering column bolts when my '65 Barracuda was disassembled. I'd appreciate finding a replacement or information as to where I can find one. Its about 7/8" inch long, 1/4" fine threads, square head. Thanks, Bob
The one that holds the bowl to the outer tube?
It is the two bolts that attach the turn signal assembly to the tube, the bowl attaches to the turn signal assembly. I took it apart about 15 years ago and remember loosing one of the bolts. I'm having a challenge putting it together as I can't find any assembly drawing in the parts or service manual. This is a power steering column that does not have a shift mechanism in it, as my Barracuda is floor shift. Having a hard time figuring out how the bolt holds the assembly to the tube.
I was told ‘66 Barracuda. I’m pretty sure 60-66 is the same though. I’ve been into a 62,64,65, and 66 and they all used those darn square bolts.
Thanks, I'll take it, they should be the same as mine. If it was a Barracuda, it would have a floor shift so the column wouldn't be different to accommodate the shifter. I have Paypal and Venmo. Its so strange that the parts book does not show the breakdown for this column.
Yeah it’s a floor shift auto/manual transmission column collar, no shift handle. Shoot me a message and we can do PayPal.
