Who can argue? Although I've never had a problem with a thermostat, I can see where someone might think the distributor is "awkward", especially if they've not figured out that the best way to work on the distributor is to remove it. I can have mine out in less than five minutes and that's on Vixen, where the room is pretty tight on the passenger's side. The manifold arrangement is really not worth complaining about, since it's pretty much set in stone. Again, I can have the intake and exhaust laying in the floor off Vixen in 30 minutes, maybe a skosh less. But of course, all of the studs are good and have high temp grease on the threads so they will not break off. The plug tubes? There are red silicone tube seals available that last several plug changes, so there's no problem there.....unless you leave the metal gaskets on the plugs. Then they do tend to leak a little. I will agree on a point you didn't make. Everything about the slant 6 is from a different era. Just look at the crankshaft. Looks like something out of Fred Flintstone's car. The whole thing defies logic, but they run and keep running.
