hemicop
Please put me on the list..........
Can you put me on the list too, also if you sell a pdf version I could always go to staples and have them print it.
Now that's the way they should have looked from the factory—-
When I was doing mine I found that the body lines at that 3 and 9 o’clock positions was the optimal place to change the transition, both below and above. The bottom front I ended flush to the tub and the bottom at the rear was not altered. Once I had the left side done I made a template and used it for the right side. Building the tub into the wheel opening lip took lots of time.
Beast!!!I run a 12” rim with the mini tub to the frame rail.
The street tires are 29 X 15”. The cross section of the tire is 15”
The slicks are 15.2” cross section & 13” tread with.
View attachment 1716416492View attachment 1716416494View attachment 1716416496
Absolutely love this car!I run a 12” rim with the mini tub to the frame rail.
I have a 29.5-11.5 w HoosiersWith this modification, and the leaf springs moved inline with the OE frame rail, how wide of a section width tire is possible that won't protrude past the fender line, and have about an inch of clearance to the leaf spring?
Sorry, I didn't see your much better pictures of the finished product before I posted my junker lol.I run a 12” rim with the mini tub to the frame rail.
That's 15.5 section width.
15 × 12, 2.5 backspace wheel.
They are I think what you're wanting to see.
The tread itself is 1/2 inch inside, section is flush.
I also have a 48 inch wide housing iirc .
Sorry, the 1st pic is car on jack stands , zoom in on the 2nd.View attachment 1716422880View attachment 1716422882Your leaf springs register in and are directly under the rear frame longitudinals? And how close are the inside of the tires to the leaf springs? Thanks!
Unfortunately I changed all the rear frame rails so I can't give the measurements that were.Thanks for info and pics guys
Are your leaf springs inline with the OE frame rails? And what is the tire to leaf spring clearance? Thanks!I run a 12” rim with the mini tub to the frame rail.
Sorry for the delay, I had to run out to the garage and take measurements.Are your leaf springs inline with the OE frame rails? And what is the tire to leaf spring clearance? Thanks!
Thanks for all the detailSorry for the delay, I had to run out to the garage and take measurements.
In the picture you can see I offset the front spring hanger .625-.750.
The rear of the springs is in line on a slider.
My total backspace with the section width included is 3.625 , so there's about 4 inch clearance at the spring. There's 3.5 clearance at the top.
I hope this helps.
View attachment 1716425233View attachment 1716425234View attachment 1716425235View attachment 1716425236
You're welcomeThanks for all the detail
1/2 inch out furtherIt is interesting the limitation on rear tire size on the Dart without the body mods etc. isnt the Duster and A body Barracuda more forgiving?
This is a real deal pic as they were picked up at Caniff and Mt. Elliot in 68Unless info for these two pics found on the webb are wrong.
Not sure of your description of wheel well here. Can be the angle fooling the eye. Lower body side curving under car.
This pic here is same car (Bagshaw´s) different angle. To me front lower part of wheel well looks to be intakt... unless of cause two very different cuts were made on same car. But I dont thing we shall exaggregate the fact some differances occured.
The Barracudas did not have any modes done to them from Chrysler or Hurst.
One has to very carefule when judging pics. A picture from 1968-69 usually shows a car not having any modes done to it. NHRA did not allow any. 1970 though, same car may run Pro Stock, and same wheel well may look different.
Now the race is on and you can see all kind of modes start to show up on cars.
A good sighn is if car is running SS B Class. That means either 1968 or 1969 and as said no mods where allowed.
You mention a 48" rear end width, is that to rotor hat or drum surface where the back of the rear wheel sits flush?I have a 29.5-11.5 w Hoosiers
