- Joined
- Mar 17, 2018
- Messages
- 17,087
- Reaction score
- 41,693
Your play list search has got to be all over the map! From FFDP to a box of frogs? Holy smokes!
That looks nasty
You hit the right one....Opps sorry what screen did I hit.
These have to be rotated while pressing them in. Then cycle e-brake to bring them close to rotor. Pain in the butt.Every disc brake set up i have done, I just use a steel plate that spans however many pistons there are and a C clamp. Go slow. Works great
Yep, rears with E brake. Sold a lot of those tool kits and boy do they work better than the Lisle cube.These have to be rotated while pressing them in. Then cycle e-brake to bring them close to rotor. Pain in the butt.
Then on to another project, I guess.Lets see, brake pads on all 4 corners. Front rotors. All guide pins cleaned,lubed and pad contact areas bead blasted. Front sway bar links replaced and one bellows on the steering rack. Wheels have to go on and muffler needs to be replaced.
And fix headlights/right signal.
I think im done..
??? Your truck or what?Brother figured out the shifting issue on the 4- speed
Sweet ride.
Sweet ride.
Nice shevelle.
That would do it.Brother figured out the shifting issue on the 4- speed
It was a sad flatbed ride home last weekendThat would do it.
I can believe that.It was a sad flatbed ride home last weekend
Pictures !!!!He has that one and a 65 big block.
I would have drove it depending on how far away from home you were.I can believe that.
3 dollar C clamp does the same thingYep, rears with E brake. Sold a lot of those tool kits and boy do they work better than the Lisle cube. View attachment 1716442308
