904 (32RH) Help - No Reverse
stoshzack
Member
Wake Forest,NC
Hi All -
So, I got my 32RH back into my 1998 Jeep.
However, it will not go into reverse. Well, it definitely shifts into reverse and moves slightly backward, but then stops like it is binding. It also creeps forward in neutral. Drive (D) appears to be fine. Also, I can push it backwards in neutral with the engine off.
Jeep starts in only neutral and park, so I think shift linkage is ok.
I am hoping I just need to retorque the front and rear bands.
Any thoughts are greatly appreciated. I really don’t want to pull this transmission again. Thanks
I guess I should add i just rebuilt the transmission myself. After doing some thinking and research, I am guessing that the forward clutch is staying engaged. That is why it creeps forward in neutral. Reverse is working, but fighting against the forward clutch. Maybe a stuck forward clutch piston?
I'm not sure if the 904 has a Bellevue spring, but that's what I'd be looking at and the clutch pack clearance. My recollection is that the wrong piston and spring combination and or clearance will allow the piston to "overtravel" and engage the transmission without pressure.
Get a good rebuild manual and be patient.
Thanks for the response. Dumb question as this was my first rebuild and experience with automatic transmissions. Is there a difference in thickness for the forward friction plates vs. the rear? I should have checked clearance, but did not. I remember thinking that the friction plates that they sent me in the kit where thinner than what I pulled out. They sent all the same thickness friction plates.
Well - I think I figured this out with your guys help. There is a difference in thickness for front and rear friction plates on 904/999. Front is 0.086” and rear is 0.060”. Company sent me all 0.060”. Not sure if they expected me to add a plate. As such, I am sure that my clearance is off on the front drum.
Don’t beat yourself up over this .
At least you tried .
Always use a manual to check your clearances in an automatic .
When I did my first one,,,I couldn’t believe that the clearance was so high on some of the clutch packs .
They can trip you up,,,,very easy to get the wrong settings if you don’t measure it correctly .
However,,,,you can fix this,,,keep trying .
The reverse servo and the band operate reverse .
So I don’t understand why you have forward gears and no reverse ?
The rear servo snap ring hasn’t popped out of place has it ?
Tommy
Tommy
Thanks for your comments. I think I do have reverse, but it is fighting the forward drum motion. Basically the two cancel each other out and it doesn’t move.
Okay
So if all forwards gears work then
It could be the band system
The planetary
The valve body
Maybe even some more stuff
But check the easy things first
Check your valve body
It sounds exactly like a transmission that has a trans brake in it
Okay
The planetary
The valve body
Thanks. So, I had the valve body professionally rebuilt. Not saying that is not it, but I would think it is something I did first.
