Gauge pin question
TheGrateRonzini
Western New York
Ok, 67 Rallye dash, the three pins above the speedo on the printed circuit, anyone know what order they go in? My plastic connector is gone and I have three bare females (giggity) Does it matter which they go to? They each only power a dash bulb… right?
You MUST get a wiring diagram and fully understand what the wires do.
Otherwise you could hook a ground to a live terminal and fry the cluster and your under dash wiring.
Red pin goes to the drivers side turn signal
Yellow goes to 2 dash illumination bulbs
Green goes to the oil or brake warning light
If anyone has this terminal loose and will loan it to me I'll reverse engineer it.
I have the round terminal REed I did not know about the rectangular one.
PM me if you can help
Blinkers. Red orange and lt grn. Orange for sure in the middle. I think Lt Grn is low and away from the other two. From what fsm says. I think red is left green right. Wasn’t sure if anyone knew off hand. I also have a second 90* stud connector coming off the fusebox like the one the voltage limiter capacitor. I guess Ill have to find out what that is doing. There is a butt connector mid wire, so I don’t know if it’s original. Could be a ground,
Car has battery disco, I pulled the cluster to fix pins and one of the bezels was loose. I put shrink tube on the bare connectors for the time being to avoid contact.
I probably have that piece at the farm on or from another car. If so, I’d be willing to de-pin the other harness and send her for a trip. Probably going out there tomorrow. Unless someone gets ya one first
At this point some dimensions ( length, width, depth, terminal spacing. ) i have all the terminal internal info from the round connector
some good clear close up photos
it looks very much like the 2 terminals on the Dart standard cluster
DO NOT ASSUME ANYTHING.
Most oem wiring will look like the other connectors so if it looks out of place it probably is not OEM
post a photo
The '67 Barracuda instrument panel is in the '67 Barracuda Supplement.
This should be a direct link:
http://www.mymopar.com/downloads/servicemanuals/1967_Plymouth_Service_Manual_Supplement.zip
if not, its on this page Service Manuals – MyMopar
There's also pdf of the shop manual diagram by @1969383S in this post.
Make sure you get the '67. There are changes each year.
Diagram wire codes covered here
This assembly drawing may be helpful
I think your looking at instrument panel circuit board on the driver's left.
Here's the connector on my '67
I have a fully functional prototype of the flat connector, I'll send off a parts order in a week.
Welp, I guess I’m a Dodo. I looked at these several times. Couldn’t figure it out. Got my lazy *** out to the garage, 3rd fuse in line, ACC, funky stud connector… I’m looking at the cigar lighter power. Thanks everyone for the help
Dana67, let me know when you have some connectors!
I bought a colored laminated 'placemat' diagram years ago.
Very helpful and stays clean.
It's for a 67 however the wiper piece is incorrect for 67 but correct for 68.
