The Green Brick decimates all.
I allready mentioned your system has more room, so not sure your point. I gave you credit for what your system does, which is provide more room, give a guy a rack and pinion, and supply all new parts. And I have mentioned your welding is superior to the other systems. What my hangup is, simply, like THIS thread started with, is does your system out handle a torsion bar suspension? And my answer is no, I can go faster on the same tire and weight with my torsion bar suspension than you can with your coilover kit. I'm willing to prove it, in public. But you gotta pony up 10k cash, and agree to my simple terms. OR we can just agree to disagree, I dont care. I have no ill feelings against you personally, I'll still consider you a mopar freind regardless.
I understand, some will obviously never get it.....and I'm A-Ok with that.
How about if HDK, or any other manufacturer of a coilover conversion wants to REALLY show a handling advantage we do a shoot out? Let's say, each competitor puts in 10k cash into the pot, everyone weigh the same, scaled percentage the same on all 4 corners, and everyone run the same wheel/tire combo, (some spec tire) and we can run a professional road course or asphalt oval? Fastest lap time takes the pot? What yall think?
I already put up. I picked a guy who had no big luv for the coil over / rack conversion but had what I needed.....an open mind. He found that it made his Gen III conversion much easier all while increasing room, dropping nose weight and gaining adjustability.
Sorry if that isn't good enough for ya......BTW, maybe I missed it, but ya' got any pictures of your contributions to our hobby?
Who throws into the pot for all the guys running Mopar suspensions?How about if HDK, or any other manufacturer of a coilover conversion wants to REALLY show a handling advantage we do a shoot out? Let's say, each competitor puts in 10k cash into the pot, everyone weigh the same, scaled percentage the same on all 4 corners, and everyone run the same wheel/tire combo, (some spec tire) and we can run a professional road course or asphalt oval? Fastest lap time takes the pot? What yall think?
45? More like 50-60 now.You wanna put up 10k and see if your stuff can out handle a 45 year old obsolete torsion bar mopar?
Well I was takin for granted people weren't tryin to autocross in Christine. LOLLol, it's older than that right? First introduced in 1957, designed before that. So, minimum 68 and more like 70 years ago. The Forward look car set up was a little different, but not much. Same basic design. They do 73+ swaps for spindles and brakes, it's close enough.
well, that's just great... now i have another thing to add to my vision board.Well I was takin for granted people weren't tryin to autocross in Christine. LOL
I have no doubt a road race Christine would work. How cool would that be?I mean, I haven't seen it. But the suspension design is pretty dang close. Heck I even looked at some of those forward look LCA's, they look very much like the '73/74 B body LCA's that allow for more suspension travel than the A-body stuff.
Just one more service I offer.well, that's just great... now i have another thing to add to my vision board.
...and I wanna say also, I think the HDK kits are probably by far the best at what they offer. I think deciding what factory and aftermarket suspensions can do better than the other is splitting hairs, mainly because the factory design is so dang GOOD, it can pretty much do everything. If you want header clearance, coil overs and a rack and pinion, I think the HDK systems are head and shoulders above the rest. Also, no one can argue the HDK stuff isn't more modern. I don't have enough sense and certainly zero experience with aftermarket suspensions to say what WORKS better. I've done a good bit with the factory design and I can testify to how well it works.
i can just weld two together right?You're gonna need some BIG torsion bars!
I meant with the control arms, rack provision, coil overs. All of that IS modern. I didn't say BETTER. Because quite frankly, I just don't know.More modern by how much?
MII suspension is only a couple years newer than the A-body set up. Spring and a shock is a spring and a shock. And the physics of the thing hasn't changed, well, ever.
Hello Denny
Where is the car with this suspension set up that has been run a couple hundred laps on a road course? I have over 6000 laps on torsion bars......
congratulations.
just an observation......I been around racers and hot-rodders all my life, most will push you out of the way to try anything new...... always looking. Some don't
your call what camp you are in.
Hey Denny,
First of all, thanks for all the valuable input you have provided over the years. Trust me, there's a whole lot of us who appreciate your opinion as its based upon a lot of years of custom fabrication. Your builds posted on here speak for themselves.
As for these aftermarket systems being built for people who know nothing about suspensions or custom building a car , that's a crock of steaming ****.
There's dozens of members on here using them that know exactly what they are doing and are very well researched.
Personally, I have done all the mods to factory suspension parts including steering box mount (first suggested in Mopar Action by Rick) , larger 11/16 tie rods , reinforced control arms, rewelded and gusseted k-frame, de arched superstock springs, different torsion bars , rear sway bars, different wheel/tire combos and on and on.
So have a lot of members on here who have switched to RMS or HDK .
And.. Guess what?? This wasn't cheap by any means either.
It comes down to this.
Spend a ton of time experimenting with the stock stuff and miss enjoying your ride (especially as you get older) or upgrade (yes, I said upgrade) to either of these incredibly well built and engineered aftermarket systems and still have a car that performs exceptionally well.
So far , all the naysayers on here have only used the stock or modified stock components and have never tried HDK or RMS. There are several, including me who have tried both. You are correct. Its a vast improvement in ride, serviceability, header clearance and performance.
For the record, I built my car in a 20 x30 garage. It is a ground up, nuts and bolt resto mod . I read everything I could find on here including a lot of posts by the guys who modified stock suspensions an those using HDK and RMS. It was an easy choice.
Hats off to the guys who know how to make the factory components work well but trying to diminish the innovators such as HDK or RMS for trying a new approach is very closeminded.
I, for one celebrate their imagination, innovation and tenacity to improve our cars.
Here's what I started with..
Here's the type of cars I play with . I hold my own , even to 100+ MPH.
I agree 100% with thisRoger that and thanks.
on a side note to who is fast?....I have seen guys with the trickest, best engineered, most (dynoed) horsepower and torque imaginable do nothing but get in the way as the ones "with a set" fly by with what they brung. My money is always on the one who knows how to gas it.
Sorry, but I think the "more modern" argument is just silly.
The reality is that the basics for most suspension design happened in the early 1900's. Seriously.
Since then sure, we've got better shock valving, some manufacturing improvements etc, but the basic designs for an unequal length, independent wishbone suspension has been out there for so long that it's pretty hard to argue one variation on it is more "modern". Pinto vs Valiant is a pretty fine distinction.
