Tim aka Racer Joe was not a customer.
I met Tim at MoParty, I recognized his Duster from his posts and thread on FABO but one could not miss how he stood out from the majority of his competitors. I walked over and introduced myself simply 1) because I like to meet my FABO friends and 2) to congratulate him on his skills.
After MoParty, I kept thinking I need to build an Auto-X ride to demonstrate .....
As I closed in on turning 70 and reality checked in, I remembered Tim, who (IMO) was in no way in the coil over / rack conversion camp but had mentioned he was planning a Gen III swap. He seemed like he would be a great candidate so I reached out to him.
My offer was simple, try it (on me).......be honest in evaluation, nothing needs to be hid from anyone. If you do not like, especially if it makes you slower, I will send a call tag, (free to post whatever the results are, good or bad) but if you see its advantages and use for a year, it is yours to do whatever you want.
Since he knew what to expect (baseline) with his already tuned OEM suspension and bad-*** small block, he initially kept that engine / transmission combo to verify the HDK was not going to cause him to go backwards. Only then and as he saw the possibilities, did he slip the Gen III in.....with ease.
Ok, so you sponsored Tim. That's great! But how does that mean he's unbiased?
that the OEM suspension is not superior in any way to my HDK, if fact HDK can hold its own and with the other benefits of the conversion, can be a plus for builders that are continuing fighting for room, particularly header clearance, rear steer component clearances, hard to align to more aggressive specs and ease of different Mopar engine swaps. I had plenty of customers with great aspirations of building an Auto -X I could of reached out to, but wanted a non-bias evaluation.
Right, so, some of these claims still aren't true.
OEM isn't superior in any way? Sorry, but Tim's numbers showed that OOTB the HDK had worse camber gain than even a mild OE based system. Yes, with 2" extended ball joints he made it better, but now that's comparing a tuned HDK vs a nearly bone stock OE set up.
OE is not hard to align to more aggressive specs. In fact, Tim is using the same UCA's as I am- SPC's. My OE based suspension is just as adjustable, and just as easily adjustable, as an HDK. I literally set my alignment the same way as Tim does. Comparing an HDK to factory components is not a genuine comparison, especially when a set up like the one I run still costs less than an HDK. Bolt on a set of SPC UCA's and we're talking about the same level of adjustment. Bolt on your UCA's vs a set of tubular UCA's with additional caster built in and we're talking about the same level of adjustment and range of specs. Only comparing your components vs bone stock components is there an advantage for the HDK, but that's apples to oranges.
And yeah sure, more header clearance to run the same headers as everyone with torsion bars does anyway. And a rack, which is nice.
Engineers have examined HDK products, always amazed at not only the quality but the attention to detail for strength with function. For those in Australia where I have sent numerous products, they are required to go thru extensive examination for certification. Following signed / acknowledged non-discloser statements from all involved, I provided (years ago) samples of all required components along with PDFs with specs for testing. They not only passed but the engineers remarked that they thought they were superior in construction to the OEM components.
As far as lasting performance......20 plus years speaks for itself.
BTW, you guys can talk **** all day (and night) long......my $$$ will always be on the best driver.
Mopar to ya'
Denny
Hey, that's awesome. Getting through Australia's certification is a
huge deal, and it definitely a credit to the build quality of the HDK. As I said, there are a lot of builders out there that have made great stuff without actual engineering.
Spend a ton of time experimenting with the stock stuff and miss enjoying your ride (especially as you get older) or upgrade (yes, I said upgrade) to either of these incredibly well built and engineered aftermarket systems and still have a car that performs exceptionally well.
So far , all the naysayers on here have only used the stock or modified stock components and have never tried HDK or RMS. There are several, including me who have tried both. You are correct. Its a vast improvement in ride, serviceability, header clearance and performance.
I don't think some of these comments are fair either. Spend a lot of time experimenting with the stock stuff?
The basic formula for making a torsion bar car handle well has been around since before the green brick, and that was 32 years ago. Yes, there are some tweaks to that as tire compounds continue to get better, but you can look at the builds of any of the torsion bar cars that are participating in track events and autoX and see that they are all quite similar.
And I think Tim has shown quite well that you STILL need to tune the coil over conversions. You still need to mess with extended ball joints, you still need to "experiment" with wheel rates and sway bar settings, etc. Getting to a high level of suspension tuning with EITHER system takes time. An HDK OOTB is no closer than say, buying everything on my component list for the OE based system and running it. Both still need tuning, you can literally see all of the tuning Tim has done in this thread. He didn't just "bolt it on and go".
Hats off to the guys who know how to make the factory components work well but trying to diminish the innovators such as HDK or RMS for trying a new approach is very closeminded.
I, for one celebrate their imagination, innovation and tenacity to improve our cars.
I'm not trying to diminish Denny's accomplishments or contributions. Not at all!
I'm just trying to get through the salesmanship and advertising exaggerations to the real physics and geometry. I keep seeing claims of "superior" being made, by guys that are still losing events to torsion bar cars. The evidence, the geometry that has been shown, well, none of it points to coil overs being "superior". They're a spring and a shock with a less efficient motion ratio than the torsion bar based system.
I’m happy to see I’ve set this thread on fire again. It’s so comical how quickly panties get bunched up in y’all’s asses. If you don’t like it, don’t buy it. The thread was intended to provide information based on my personal experience with the two setups.
I also love the speculative engineering from people who likely never even took a calculus class let alone define failure points of steel using formulas. I realize there are likely some engineers here making valid points, but I don’t see yall designing a new mousetrap.
Also, please tell me how this is a pinto/mustang 2 front end. The geometry is nothing like an M2. Sure it has an m2 spindle, but that’s it. If you put a Miata seat in your car, does that make it a Miata? I could use a GM A body spindle on my HDk if I wanted to, I just don’t want to spend $800 to “try” it. I guess maybe I should then I could say I have Camaro suspension on my Duster.
I’ll see my way out of this **** show. I’ll be out driving and autocrossing my HDK setup without any worry of crashing and burning, while most everybody’s car is sitting in the garage and never sees the light of day.
Yeah, it's not me whose "panties are in a bunch". Seriously, I just pointed out that the observations you made don't prove the conclusions you reached.
With the exception of the SpeedTech stuff out there using a corvette spindle, most of the coil over conversions for these cars are MII based. That's Pinto suspension. Using the MII spindle means that some of your base geometry is absolutely the same. It's too short a spindle, for example, which is why you're running 2" extended ball joints. What about the steering rack and all of its geometry? MII. What would you call the suspension on my car? It's about as much Duster as your suspension is MII. I use the spindle and control arm mounting positions, everything else is pretty different from factory. Your suspension is actually a mix of MII and Mopar geometry that was never evaluated by either manufacturer. Hell we use the SAME UCA's, which is why the claims that your suspension is easier to align or has better specs are just ridiculous. I literally adjust my alignment the same way as you do.
And yes, I have an engineering degree, so I've taken lots of calculus which is only the entry level requirement to even begin to understand engineering calculations. My actual area of focus was structural analysis, so yeah, lots of materials science classes too. Of which "failure points of steel" may have come up a few times. No, I haven't designed a "better mousetrap". I have a full time job, and quite frankly no one has proven yet that they've actually made a system better than using the OE based torsion bar set up. All suspension is a trade off, there are pros and cons to ALL of it. I can do everything I need to do with the set up I have, so, why would I design a new one?
I drive my car thousands of miles a year in my less active years. So, swing and a miss on the garage queen insults too.
You did breathe fire back into this thread, by once again making claims that just aren't true and twisting the argument against the coil over conversions. No one talked about corner weights, people have talked about structural loads. Saying the corner weights are almost the same doesn't mean much of anything, other than it once again shows that the "superiority" of the coil over conversions isn't at all clear cut if a car with OE based suspension has corner weights in the same ballpark as one with a full conversion. So where's the advantage? Again, it's awesome you haven't blown apart any spot welds or developed any cracks, but if you had that would show a MASSIVE issue. A couple years of operation without catastrophic failure does not prove that everything is perfect.
By all means, go drive your car and enjoy it! But don't think for a second that I don't do the same.
