[WANTED] 68 Dart fender mounted turn signals wires.
Dor-Dor68!
Active Member
Los Angeles
Rating - 0%
0   0   0
Hey everyone, been slowly upgrading and restoring my '68 Dart. She has the fender mounted turn signals "bullet" style....a little back story:
The drive side still has an old crusty lens, while the passengers lens is gone. Bought new lenses and gotten the new bulbs for them, but after swapping the new stuff into the one that had the lens, it didn't work or lit up. So im assuming the wires might be toast. The side fender turn signals also dont light up when I turn the lights on. So I gotta check all my wiring.
As for the passenger side, the new lens didnt screw in at all. So somethings missing.
If anyone has a pair of the wires please let me know and also any info or help would be greatly appreciated. I'll add some pics of what im looking for and my Darts front end.
Do you have any turn signals that are working as expected ?? If not maybe start by checking fuse box. Also maybe run a temporary jumper wire to the fender signal and see if they illuminate ?? What about the 4 way flasher ?? Did you check the turn signal flasher ??
Yeah the front markers on the grill do work and illuminate when I turn the blinkers either left or right. They also turn on when I pull the first click on the headlight knob. Both rear and front flashers work when I turn em on.
So I'll try the jumper wire and see how that works.
Thank you so much for ur input.
I'll come back and let u know what I find.
The fender turn signals do not light up with the park or headlights. They only flash when u have the signals on. I donk know for sure if they flash with the emergency flashers but I would assume so. Kim
Yes should flash with 4 way flasher. Also the assembly grounds to the fender so maybe check that also
