1st time out with W8… 2 videos now
9secRR
Saskatchewan
since this is the first time out with the new combo, i decided to do footbrake the first pass. i didn't know what the car would do. left off idle (1700 rpm idle), shifted at 7200.
1st pass, 1.35 60', 5.83 @ 118.30, 9.18 @ 145.02. straight as an arrow and smooth. very happy since i changed a lot since the W2 combo.
2nd pass, 1.34 60', 5.83 @ 117.16, 9.19 @ 144.46. car came up high, did a 80' wheelie and broke the 60' beams with the back tires. i used the trans brake on this pass. that was the only change to the car.
3rd pass, 1.23 60', 5.81 @ 106.79, 10.45 @ 84.76. made shocks changes on all 4 corners to tame the launch down. air shift didn't go into 3rd gear so i aborted the run.
4th pass, 1.23 60', 5.81 @ 108.51, 9.33 @ 140.19. made a few more shock changes to the rear. very smooth pass. air shifter didn't shift into 3rd again so i manual shifted into 3rd, but didn't get it in time to nail the shift perfectly.
5th pass, 1.23 60', 5.73 @ 118.20, 9.08 @ 144.65. made another shock change to the rear and raised the shift rpm to 7600. still had to manual shift into 3rd but i was ready this time and wasn't late. car picked up in 1/8 and at the top end.
i'm super happy with the 1st outing with this combo. checked a couple plugs and timing was good. just a bit on the rich side but in the safe zone. this was all about getting the suspension dialed in. now i can get after it on the tune and see if i can get a 8 sec times slip.
3rd picture is how we have it leaving now.
air shift didn't make the 2-3 shift. i had a bit of trouble getting it into 3rd gear manually
btw you build the motor yourself? I am jealous of you guys that get to go racing.. I love watching brett millers motors when he posts videos.. those W motors are insane
Yes I did. At the same time I built a R3/W9 that’s in a friends Daytona
Nice results again. What are the details of the W8 motor? (Cam, compression, carb, head work, etc...)?
414 cubic inch
3.875'' stroke
4.125'' bore
16.4:1 compression
704/694 lift bullet roller, 279/285 @ .050
1.6 jesel rockers
isky lifters
2.185/1.65 valves
msd crank trigger
mopar performance aluminum block
dry sump, peterson pump
chapman w8 heads, flow 354 @ 850 lift
CFE tunnel ram
2 toilets running M5 methanol
1-7/8''-2'' stepped headers i built
904, 6400 stall
4.86 gear, 9''
ladder bar
QA1 single adjustable shocks all 4 corners
14 x 32 MT's
2700lbs race ready
needs more camshaft to take advantage of the head flow. next year i will get a new one ground.
edit.... forget to mention the rods. they are Fowler aluminum and the pistons are JE
