Fine Tuning a 360 Magnum with a Brawler "Double Pumper"
So on a normally setup DP, half throttle is just about 75% or so open on the primaries right? Give or take.
If I’m feeling it right, I think I can tell in the pedal when the secondaries are about to open because the pressure on the gas pedal changes, feels like the cable gets stiffer (the linkage getting ready to move on the secondaries). When I’m cruising at 45 in high gear on flat ground and I get on the throttle, this is around the point where I can hear the engine start to bog/sputter (which happens at about 10-11 inches vacuum). Does this mean I should still be looking at a 10.5PV?
I would imagine this would overlap with lower throttle input on a grade with payload or something. Or is that going to be way too much enrichment too early, and I would not really be able to easily tune a true WOT scenario because the PV is dumping its fuel early
This is how I think of it. On the primary side your carburetor has three main jets. Two are open all the time and the other is controlled by vacuum.
The spring on the powervalve sets the timing of the powervalve relative to vacuum. There is a starting to open point and a fully open point and a starting to close and fully closed point. There is only one number stamped on the powervalve. So don't take that number as gospel. The amount of fuel supplied by the powervalve is controlled by the power valve channel restrictors.
So on this third jet (powervalve) you have timing controlled by vacuum and spring calibration and the amount of fuel controlled by the powervalve channel restrictors.
In the picture below is a powervalve that somehow the spring misplaced itself taking preload out of the spring lowering the amount of vacuum it takes to close the valve. This was on a circle track car. The complaint was that the car would run good off the corner and then halfway down the straightaway the car would fall on its face.
The powervalve doesn't know load per se. It only knows vacuum. Load can be roughly translated to vacuum but as shown in this example it is still operating off vacuum not load. The engine is at full load all the way down the straightaway. At wide open throttle the vacuum coming off the corner was low enough that the powervalve was open. At wide open throttle as the rpm's increase so does the vacuum even though this is still a low amount of vacuum it increased to the point that it was enough to overcome the defective powervalve and close it midway down the straightaway leaning the motor to the point of it falling on it's face.
All this is to say that the powervalve is used to add fuel based on load but it does so with a vacuum signal. Hope that makes sense.
Yeah that makes sense, good explanation too. I’m really going to base it off of the plug reads and how the engine sounds/responds to certain things. I’m going to start trying different variables and experiment
Don't ignore you o2's. Just remember they are one piece of information. I think you will find them to be helpful. In end it's not exactly what the o2 number is or how the plug looks (show a picture of a plug and you will get many different interpretations even from legit experts) but how it performs. As long as it is a safe tune.
My biggest hurdle right now is I basically understand how all the circuits work by themselves, but I don’t know how they tie in and affect each other
I have a feeling you're going to figure it out.
It's impossible to say.
First and forermost
What happens in the cylinder when the intake valve is closed and the spark is fired too early? Does the kernal grow? If it does grow does it push on the cylinder too early? What effect does that have on power?
Yea you let in more air but there's no more power. That's one reason for that happening.
Second
What circuit(s) are in play? Probably several. Tune the steady state conditions first, then deal with the transitioning situations (moving the throttle) places where the circuits are overlapping. This is why my psosts and others about Tuning for Performance are in a sequence.
First and forermost
Second
Alright, I’ll do some rereading, probably on a desktop because I keep getting ads everywhere on my phone lol
This is why getting an engine on a dyno with an operator who doesnt just sit there and make acceleration tests.
You can see all of it on the O2’s. I’ll say it again to you and you do what you want and I’ll say it this way.
How many engines were tuned without O2 sensors? They didn’t foul plugs, detonate themselves to death and the had points ignition. They learned to read plugs. If you want to learn to tune you MUST learn to read plugs. Will you be an expert in a month? No you won’t. I’ve been doing it since I was 12 and I get jacked up a bunch.
Shrinker (I forget his real name) was a tuner among tuners and he taught that it’s a continual learning experience. Different fuels require a different “read” on the plug and different plug brands read completely differently at the same air/fuel ratio.
You are talking like you are trying to tune to a number and Im saying you have the cart in front of the horse. As I said, you can be rich on the O2 and lean at idle. Tuning with EGT is the exact same thing. Skyrocketing exhaust gas temperatures can be either lean or rich. Make it fat and the fuel is still burning when the valve opens and the EGT looks hotter than it really is because all that heat generate isn’t used to make power. It’s just wasted heat and power.
On top of that, guys start retarding the timing and the EGT goes up even more. This is why if you can look at a plug and at least make a rudimentary read of it you could see it’s pig rich and the timing is retarded. I’ve seen sharp guys get lost easily when looking at a plug would have explained the data.
Im not saying to not use the O2 sensor, Im saying to stop looking at the numbers for now and make it happy at idle, cruise and WOT. Then get the O2 sensor going, see what your numbers are and make SMALL changes to ONE circuit and look at the O2 sensor and compare that to the plugs and how the car is running. If it gets better then you know which way to go.
And when you have tuned yourself silly and you think you have it nailed those are the numbers you tune to for that engine at that time in that chassis with that fuel.
I see guys running WOT O2 numbers at 12.5 and think they have it nailed but the plug says it’s too fat. So you tune it for best MPH by leaning it down a bit, because MPH is horsepower, not ET. And then we put the O2 sensor on and it’s reading 13.2 and the **** storm starts. Most of the time they fatten it back up and the MPH goes down so it lost power but the plugs said it was safe. Done this many times. Because they are married to a number and not to the plugs.
You do what you think works best for you, but thinking you need to be able to read a plug like an “expert” and until you can you don’t need to look at them you are handicapping your learning to tune learning curve.
As for the comment ask different guys and get different answers I’ll agree. How do you know who is correct? NONE OF THEM because we aren’t there to look at the plugs. I don’t care who you are, looking at a plug from a picture is a wild assed guess at best.
I look at the inside of the shell, the bottom of the porcelain, the color of the metallic parts and even the edges and shapes of the sharp corners of the plugs and I do that with an otoscope. I use a 20 dollar Dr Mom otoscope and you can see a lot more with that than your eyes. Even the lighting you are using can make a difference.
Many times I walk outside to look at a plug on the dyno because I can’t figure out what I’m looking at. And I’ve been doing this a long time. And if that doesn’t work I cut the shell off the plus so I can get down to the nitty gritty. If I’m still not believing what I’m seeing I call my mentor and run through it with him.
My point is you don’t need to go that far down the rabbit hole if you don’t want to. But you should be able to look at a plug and tell it’s condition with 75-80% of what it’s saying very accurately.
A day on the dyno, and I mean a good day where we aren’t wasting time breaking in a cam, dropping in inner valve springs and **** like that and I could get you to 75% very easily.
Look at your plugs. Believe the basics they are telling you.
Okay I have a follow up then. Well a couple lol
So for tuning WOT via the plugs, I’m aiming for a brown/tan but not white and not black/wet color?
And let’s say I get my idle happy at peak vacuum, but my plugs read lean on the low speed cruise. Should I open up the TSR or close up the IAB and readjust the screws?
Edit: smaller (close) IAB, not open it
And let’s say I get my idle happy at peak vacuum, but my plugs read lean on the low speed cruise. Should I open up the TSR or open up the IAB and readjust the screws?
When you are tuning WOT you need to pull on it for a quarter mile. You can do it in an eight mile but you may be a touch lean if you pull on it longer than that, so keep that in mind. If you are trying to do WOT on the street and you trim the fuel down to make the plug read correctly you need to be very careful if you do go to the track because you can be lean.
If you will never pull on the engine for that long because you aren’t going to the track then you’ll be ok with whatever distance you can get.
As for how it looks, it should have an .080-.125 wide witness mark at the bottom of the porcelain. For a pump gas street car then I’d say .100-.150 but shoot for .125. If you feel like you can tune and you keep up on it then you can go down to .080 wide but your margin for error is damn near zero. A decent weather change and you’ll be pretty lean pretty quickly.
Im talking about when the porcelain where it meets the shell. If you are running a very cold plug, like you have 14:1 compression it’s easier to see down in the plug than if you are using a plug that is for 10:1. Thats why I suggest a Dr. Mom otoscope. They are pretty inexpensive and they work.
You should NEVER see brown a plug IMO. The exception is maybe if you are running points and even then you’ll be on the rich side but sometimes if the ignition is weak you’ll need that. Spark mark is real and if I don’t see it I try and figure out if it’s a weak ignition, bad plug or wires or if the plug material is so hard it won’t spark mark. I hate those plugs.
I have a question for you. Why are we tuning idle for highest vacuum? You can, but if you do you can get into tip in issues and misfire at idle and then the O2 sensor says it rich. Unless the engine is showroom stock or really close to it.
I do it differently. I start with what I think is the correct idle feed restricter and what size idle air bleed I want to start with. It also matters if it’s a two corner or four corner idle. If it’s two corner then I don’t use the exact same package as I do with four corner idle. Even though fuel is moving through the secondary side you can’t adjust it and you have to account for that.
Let’s say four corner idle. For a 750, Im starting with an .028 IFR and a .072 IAB. That should get me at 1.5 turns out on the screws. Thats not a magic number but it’s about half way on the available adjustment.
Once it’s warm I start on the drivers front (it doesn’t matter but I’ve been doing it that way since 1980 so I stay with it) and I screw it in until the idle speed changes. The I come back out until it comes back to the rpm it was and stop and give it 10-15 seconds to stabilize.
Then I back it out until it slows down. I stop and go back in until the idle is stable. An 1/8th of a turn can be a bunch so take your time. Speed comes with repetition.
Do that to all four screws. When you have it done take each screw OUT 1/8th of a turn and leave it. If you have a bit of a tip in issue then go back out a 1/16th of a turn on each screw. Do that until the tip in is gone.
You might lose 1-2 inches of vacuum but it will idle correctly and it won’t stink. Then put your O2 sensor on it and read it. That’s what your engine wants, regardless of the number. Now you can tune with it but using an O2 sensor but they can be very erratic and give unreliable numbers. And you can throw your vacuum gauge on it and thats the vacuum you have at idle.
That’s how I do it. I don’t know how that vacuum gauge tuning started by I wasn’t taught that way and Im not so old that vacuum gauges had been invented yet.
On Sunday I ran over to a friend’s house to see why his junk wouldn’t idle. I forgot to mention to make sure the float level is set before you start because it affects idle. It was so rich at idle you couldn’t stay in the garage for very long before you had to get out and get some clean air. And it was smoking like a BBQ.
I set the screws 1.5 turns out and the floats and it cleaned up a bit. Then I did exactly what I said above. In a few minutes it was idling away like nothing, it stopped smoking like a BBQ and you could stay in the garage and it didn’t gag you to the ground.
Thats how I do. My friend wanted to do it with a vacuum gauge and I said I don’t do that. When I got back to my mom’s house my brother was there and I told him how it went. Then he says my friend told him he had tuned the idle with a vacuum gauge and couldn’t figure out why it stunk.
That’s how I do it.
I do the vacuum idle tuning because that’s what I’ve heard everywhere basically. Everyone says turn the screws for peak vacuum and then back them off a bit for cushion. But to summarize (it’s actually similar to what my dad told me he did back in the day.) and correct me if I’m wrong.
You start with 1.5 turns out or so, just equal on all 4. (Is .028 IFR and .070 MAB too much/little for my setup in your opinion?). Then start with one screw and turn it in slowly until idle speed drops, back out until it goes back to what it was and let the idle stabilize. Then turn them out slowly until idle drops and then go back until it’s normal and stabilize. Do the same on all 4, and adjust as necessary for any tip in.
For WOT tuning, there is a quarter mile strip not overly far from me where I can go to tune in the WOT stuff when they do test/tune days, I’ll have to do some digging about them.
In terms of my plugs, I’m running NGK FR5s gapped at .040”. They’re a step colder than stock. I read that colder would help with preventing pinging so I did it just to experiment. And as a reminder I’m currently running 16 degrees initial.
  • 700–1000 rpm: 16°
  • 1500 rpm: 28°
  • 2000 rpm: 32°
  • 2500–3000 rpm: 36°
The bowls are set currently at just about halfway on the sight glass (not plugs). Pressure is just under 6psi.
This may be an odd question but I’m curious if there’s any insight about it. Let’s say I tune my wot for a quarter mile pull and it’s all good in that environment.
For this fictional scenario let’s say I’m hauling somewhat heavy and for some reason I’m on the highway on ramp and I floor it going up hill. Given the load and the incline, the amount of time is the same as the quarter mile, but the distance traveled is not. Is this going to be the same thing to the carb, or is the whole situation different because of the load? (Or is the simple answer don’t floor a truck up hill heavy lol)
  • 700–1000 rpm: 16°
  • 1500 rpm: 28°
  • 2000 rpm: 32°
In my world, just because everyone says it doesn’t mean it’s right. It also doesn’t mean it’s wrong. In my world the majority is wrong far more than they are correct. How to set Holley power valve timing is an example.
For decades everyone was using 1/2 idle rpm to set the opening and at best it’s half wrong most of the time. And then every tuning decision made after that is based on an error. How do you correct that.
Start where you are. Then set it like I explained and see if it idles better or worse. I could be dead wrong. That’s how you learn.
Im not a big fan of cranking an assload of initial timing in an engine to make it idle. More times than not you can get the same idle or better if you tune the carb but in my experience if you need todo that the build has too little compression or too much cam for the compression. That’s how I see tuning for the highest manifold vacuum. To what end? If it’s lean missing, even if you can’t hear it then it’s still wrong. But you have 2 more inches of idle vacuum. What’s the gain?
One thing I forgot to mention is when you get idle nice and clean and the mixture screws set I take one screw and turn it in and count the turns just so I know. That will give you an idea of what the engine wants for an air/fuel mixture at idle. Turning the screws in and out only changes the AMOUNT of air and fuel getting to the engine. Changing the IAB or IFR or both changes the air/fuel ratio.
To that end, let’s say you get the screws set and you screw them in and you are three turns out. That tells me that the air/fuel RATIO you are giving the engine is on the lean side.
If the screws are only 5/8 of a turn out you know the air/fuel RATIO is rich. I make this point because that’s the two extremes. You only have about 3/8 of a turn in to lean the carb down. If you are 3 turns out you have about the same amount of adjustment if you need to fatten the idle up a bit.
Certainly you can run it and probably never get to the point you’ll be out of the adjustment one way or the other. If you don’t drive the car to huge elevation changes from your home it’s not a big deal. Im about 3 hours from the ocean by car which is about 120 miles as the crow flies. I live in a high desert valley. The change in elevation and weather conditions causes a change in IAB and sometimes a jet change and probably a timing change. That’s why I try and get the screws centered as best I can. It’s in hope of not needing to change an air bleed or IFR. Turning screws is quicker, easier and cleaner.
If you are say 3 turns out and you are lean, you can go down .004-.006 smaller on MAB to get the screws back in. If you go much more than that you made need to make other changes to go with that. If it needs more than .006 smaller I’d drop the IFR down .002-.004 and see how it goes. If it’s too fat then go back to up on MAB .002-.003 to clean it up.
The thinking is the same if you are only 5/8 out, you a drop the MAB down. If it needs more than say .006 you need to drop the IFR .002-.003 and see where you’re at. If it’s a bit lean, you can open the MAB up a couple of thou.
I hope that makes sense.
As for your timing 36 is a TON of timing at that rpm UNDER LOAD. We have to consider load (manifold vacuum) when looking at timing. At a cruise you engine may want as high as 50 degrees of timing. If you crank all that timing it (50 degrees of mechanical advance) when you stand on the throttle to pull a grade, or you have a trailer on it will rattle its brains out until it spits a rod out.
What you are doing is trying to get the engine happy with timing you cant achieve so you compromise with (using you example) 36 at a cruise. You may be as much as 14 degrees retarded on timing. That causes elevated exhaust temperatures, increased fuel consumption and a massive hit in torque at and around peak. How do you fix it? You use vacuum advance.
But you can’t have a curve like you have and add vacuum advance or it will rattle. I’ll give you an example. Im it saying this is what you need but it’s an example.
Let’s say that peak torque is 3500. And you have vacuum can that will give you 14 degrees more timing at say 18 inches of vacuum.
What if you rolled the timing back to 30 degrees at a 2700 rpm cruise and you added 14 degrees more timing with the VA? You now have 44 degrees of timing at a cruise. Fuel consumption goes down as well as exhaust temperatures. When the vacuum goes away (under load) you go back to just the mechanical advance. And it’s happy without all that timing at that load.
You get the best of both worlds. Is it quick and easy. Nope. But the benefits of doing it that way are so valuable that IMO it’s worth it.
That’s how I think about timing. I know this. Too much timing at peak torque will kill 20 foot pounds so fast your head will spin. And the fact that you have to retard the timing to keep it from detonating means that timing is retarded at higher rpm.
I hope this makes sense.
So my cam setup is almost stock. From what I’ve read it’s basically a strong towing cam that happens to have more top end. Compression is almost bone stock, barely higher if at all. It’s a 20 over piston and the block was decked for true.
I’m assuming for truly getting the timing curve dialed in I’m going to want a dyno graph and getting the mech advance all in at peak torque and ramping up following the torque curve?
I’m going to circle back soon about my idle screws once I have a good time to tweak them. Tomorrow it’s going to be raining and 60 degrees, but Thursday it will be 80 and sunny so I’m going to do it then.
On my drive home from work today though I was getting some bucking at low rpm which makes me feel like it’s transition related but correct me if I’m wrong. I’m going to try to diagnose this myself and I want some feedback.
Cruising at low throttle, 45mph, flat ground. In 5th I was at about 1500rpm or so, and it was bucking pretty bad. Head was bouncing back and forth basically (and if it matters i saw the afr needle going crazy), but I could feel it and hear the engine cutting. If I downshifted into 4th and brought the rpms up to 1800-1900 with the same throttle amount, the bucking was still there but nowhere near as bad. In my head this is the transition slot having a stronger signal and flowing more fuel and or the mains starting to trickle in.
Given that at least so far, my idle screws have been pretty far in, I’m tempted to try a smaller IFR. I’m thinking that would be the better way to go vs a larger IAB given my transition seems lean, but again this is me trying to see if my thought process is correct so I’m open to corrections
Then taking that early timing and tune the carb to match it, what happens?
The answer comes from understanding the relationship of burn rate to the density of the air fuel. Would be surprised if this wasn't brought up early in this thread.
edit. Shoulda put money on it.
post 226
post 226
I’m gonna go through that post again tomorrow when my brain can absorb information lol. Still need to take a look for my springs and stuff for my dizzy as well
I could be wrong but I think you're saying MAB when you mean to say IAB.
You are most likely correct. Can you point out the line and I’ll correct it.
I just said this morning I was going to proofread EVERY post. And I did and I STILL missed an error.
If you show me the line I will clean it up.
Edit: never mind. I didn’t just miss it once, I missed it many times. UNBELIEVABLE!
Thank you for catching that. That would screw guys way up.
That would be a good first step.
Then follow the link to the thread on tuning a double pumper.
In turn that can take you to the "definative power valve thread" but that gets so in depth that you'll have to come back to it after getting a better handle on the timing effects combustion, and the basics of how the carb circuits work.
  • 700–1000 rpm: 16°
  • 1500 rpm: 28°
  • 2000 rpm: 32°
What I find is that setting the idle mixture screws to where the engine runs the smoothest is also going to be where the vacuum is highest. Usually slightly rich of this is a good starting point. I don't use a set amount of turn slightly rich and the reason is that I have found that with some combinations an 1/8 of a turn can be a big swing and in others it's not.
I didn't see mention of keeping the mixture screws set to an equal number of turns on each corner. I like to keep them all equal at least to start out. Sometimes I have to fudge that a little. Also if adjusting the screws raises the idle speed I like to adjust the idle speed back down as you go and then recheck the mixture setting. If big adjustments are made here I might adjust idle speed on the secondary shaft as an effort to keep the primary t slot in the ballpark. If the t slot gets too far out of whack on the primary or secondary you might have to address that first or keep in mind the effect that might have and deal with it later when you are more sure of where you want to be.
Tuning can be a lot of back and forth and compromise. Sometimes the difference between good enough and perfection can add up be many hours of time.
If a carb looks like it is going to need a complete recalibration or just doesn't want to get along with the combination I might just try a different carb and see how it runs with it. Sometimes this can be helpful.
If I had the money to try another carb I would but that’s not going to be on the budget for a long time lol.
Although running a 650 on a very mild 360 magnum seems to be universally agreed on. Holley recommends it and seemingly everyone who I’ve talked to both on this forum and in person has said that a 650 is a perfect fit for this engine.
Given that in most cases an engine running happiest via idle screws also happens to be its peak vacuum point, I’m just going to tune it the way that was said earlier, and then just look at the gauge and see what it says. I’m really going to have to try to squeeze in working on the carb though because of how quickly the weather changes down here lol
That sounds like a good plan.
I'm not trying to talk you into buying a new carb. Replacing the carb was more of a diagnostic suggestion. Like borrow a carb and see how it runs.
By different carb I don't mean a different size carb. 650 should be fine. Holley, quick fuel and others have many versions of a 650 with different calibrations for each version.
I’m not sure how long you’ve been poking around at this forum, but I did swap from a brawler 650 to a Holley 650. When I did the swap, it did run better. The brawler was super inconsistent hence the swap. I still do have it though it’s at my parents house.
The brawler kept “losing” its idle tune it seemed like, and also constantly had needle sticking and flooding.
Yup.
Start out the same turns out and then if you get one thats a touch off you leave it. It may be a distribution issue.
Certainly you don’t want one screw out three turns and another one out 1/4 turn. Like you said, start over and if it ends up like that again stop and see what’s going on.
Yup.
Yeah I know the dual planes are a little goofy but probably will stay within 1/4 of each other. Am I right in my assumption that if there is any deviation between the screws it would be front to back because the primaries are open further than the secondaries so they need slightly more fuel?
It’s usually not so much that, but it’s how the runners are laid out. How many corners the air/fuel has to make to get to the chamber and the difference in runner length IMO.
