69barracuda68
Member
Starter gear sticking in flywheel.
I have the 318 four speed 833 bellhousing that came with the junk 318. I have a 130-tooth 360 flywheel 10.5" clutch and pressure plate. The high torque mini starter from summit racing (sum-820441) for la small and big blocks. It turns over the engine without spark plugs but starter gear sticks in flywheel. I disconnected the positive battery cable and wired in a momentary push button switch and took video from under the car when firing just the solenoid. First video is gear going out and second video is sliding the gear back with a screwdriver. Notice the starter gear rotates toward the camera. Seems like a rotational drag and not a side-to-side mis alignment.
Is the starter nose cone location different from the 318 bellhousings to the 360 bell I don't have?
Any ideas why it sticks with the bellhousing, flywheel and starter combo?
