DionR
This guy built his own chassis using all Speedway Motors G-Comp components.
I'm trying to determine if he used the regular G-Comp universal kit or the G-Comp X as a starting point. As he is using a much taller coilover that mounts to the down bar.
Based on the earlier pictures he posted on FB, he started with the regular G-Comp setup. He mentioned moving the UCA mounts around in the video, plus he used a much long coil over than the regular kit uses. Not clear what he was shooting for when he made the changes other than an I think he said he wanted an even better camber curve. Either way, I would bet he closely approximated the G-Comp X setup when he was done.
