Corrected…I meant biggerA smaller diameter rod is going rich.
What are you trying to accomplish? Leaner idle? Leaner part throttle? WOT?Corrected…I meant bigger
leaner part throttle...I got pretty close making the small rod diameter bigger which didn't make sense to meWhat are you trying to accomplish? Leaner idle? Leaner part throttle? WOT?
What's the idle vacuum?leaner part throttle...I got pretty close making the small rod diameter bigger which didn't make sense to me
Lower than I expected 10-12 Inches with a stock '68 4 speed 340 cam...15 inches max cruise. I tested for vacuum leaks, etc. Just for fun I'm going to check when the intake valve opens and compare to the cam card but I checked centerline and it installed it at 110.5 deg. which is 1.5 degrees advanced. I don't recall why I did that. It will give me a chance to pull the covers and have a look now that its broke in and has some miles on it.What's the idle vacuum?
That's a little lower than I would have expected as well. Have you verified your vacuum gauge is correct?Lower than I expected 10-12 Inches with a stock '68 4 speed 340 cam...15 inches max cruise. I tested for vacuum leaks, etc. Just for fun I'm going to check when the intake valve opens and compare to the cam card but I checked centerline and it installed it at 110.5 deg. which is 1.5 degrees advanced. I don't recall why I did that. It will give me a chance to pull the covers and have a look now that its broke in and has some miles on it.
WHERE and HOW is your fuel filter mounted?It starts (cold) and runs and drives fine...idles fine at 700 rpm and no part throttle hesitation. If I didn't have an AFR meter I wouldn't know the difference driving around town and freeway. I haven't got into WOT analysis. Getting part throttle AFRs out of the 12s and into the mid 13s is an issue. I'll find out today if I was barking up the wrong tree with the fuel pressure.
yepThat's a little lower than I would have expected as well. Have you verified your vacuum gauge is correct?
factory lines and location...above the intakeWHERE and HOW is your fuel filter mounted?
Well that's clear as mud. Can you post a picture?yep
Have you checked cruise vacuum as well?Lower than I expected 10-12 Inches with a stock '68 4 speed 340 cam...15 inches max cruise. I tested for vacuum leaks, etc. Just for fun I'm going to check when the intake valve opens and compare to the cam card but I checked centerline and it installed it at 110.5 deg. which is 1.5 degrees advanced. I don't recall why I did that. It will give me a chance to pull the covers and have a look now that its broke in and has some miles on it.
Should be about .008.Off on a tangent here....I was having another look at this hot start issue and put my plug tester on and saw that there is no spark when cranking (at least with the engine warm). I have already tested to see that there is power to the ballast in start and run positions. Dumping a little fuel in the carb doesn't help. I was looking into other posts about hard starting when hot / starts when key is released type issues and read where somebody said that the coil will fire one time when you let go of the key. It made me wonder if that is what was starting the engine at least when hot....perhaps the pickup was weak. I pulled my new Mopar distributor today and see the pickup gap is about 0.025". I checked this before but I think the magnetism fooled me into thinking the gap was ok. I can see the large gap now the distributor out. I'll adjust, reassemble and test later today if the Ativan from the dentist trip lets me.
I put one on earlier this week. I'm thinking my hard starting issue is due to the distributor pickup....tbaNot sure if are just using a base gasket under your carb, but if you are this heat insulator from Edelbrock cures a lot of hot start issues.
Edelbrock #9266
Cool. That gap is crucial for proper operation.I put one on earlier this week. I'm thinking my hard starting issue is due to the distributor pickup....tba
No need to buy anything. Just fold a piece of paper twice and there you go. I do hope that fixes it.I bought some brass feeler gauges as my set only has a brass 0.010" gauge which I am sure would have been fine. I checked the gaps and a few were tighter than the rest so I set them at 0.008". The engine starts quickly cold and hot. I wonder if this would have affected engine performance. Oh well now I will go and check the tuning and see if there are any changes.
