69 dart vert windshield moulding
nutz
washington nj
time it find a windshield moulding
who makes a good one
i guess the windshields match a reg two door
The weather strip arould the windshield
That hold the windshield in
this?
NOT MINE!
1967 68 69 DODGE DART CONVERTIBLE A BODY USED OEM FRONT WINDOW & HEADER TRIMS | eBay
if you are talking the windshield seal
I recently used this one
Mopar A Body 67 Barracuda, Dart CONV Windshield Seal with Chrome Locking Strip
it comes with A chrome lock strip, (but it does not look much like the OEM lock strip)
FYI the windshield seal DOES NOT use seperate small chrome pieces like a HT or other versions I uses one lock strip at the bottom and the larger trim that fits around the A pilar from inside to outside.
if you are looking for the entire chromed windshield trim you will need the interior pieces
top of windshield interior and inner corners
(These should be chrome)
PLUS
A pillar trim (converts are slightly different)
(also should be chrome)
Top Latches
Convert ONLY rear view mirror
Plus the door seal retainer
Yes that's what I was talking about
So that seal fit nice ?
Car getting body work done this winter so want to cut out the windshield and replace it
My stainless trim is nice only the plastic locking strip is shot
So lock strip look wrong ?
They say extra shipping
How much ? $269 not bad
The seal fit well. The installer not so much.
Be sure you have the exterior trim available when the glass is installed. The installer got it a little too high on the glass in one spot. So the reveal to the trim is wonky
But it doesn't leak on the driver's side any more.
Not the pass side.... That's another story! ARRRRGGGGG!
It might be coming from the chrome trim catching water and then running down from inside.
This is the lock strip that came with the seal
It is very heat and doesn't fit into the side trim well
This is a NOS (I have 2 and both look the same) sitting on top of the provided lock strip. It has a pronounced curve and a peak to it.
This one is a bit yellowed.
Provided
Note the change in shadow about 2/3 way up
You can barely see it but this is where the reflective part is ( red arrows)
Ill do it myself
Or be there if i have my glass guy so it
So need to test fit with the stainless when its going together?....
What about the locking trim is 67 68 69 the same
The listing was 67 only?
Oh i got you its flat
I know that would bother me a little
Mine looks horrible yellow,peeling,cracks
Is that available or did I just deal with it
Seen your ebay listing...
no one repos the OEM style strip so you have what you have. NOS are available from time to time and as long as they are longer than the convert they can be cut to fit. As for 67 vs 68-69 I have heard it 2 ways. one is the 67 is one year only and 68-69 uses a stainless steel strip that attaches to clips on the body AND I have heard that 67-69 are the same as 67
Mine looks like what you have
Or should I say what's left of mine
So I guess i buy the one posted
Thanks
