So it is time to install a new camshaft in my Scamp. My previous one was designed for a nitrous application and that notion is gone. Now I am at a point where I am considering just replacing the solid flat tappet with a hydraulic roller, solid roller or even a hydraulic flat tappet. The more I read, the more confused I get. The car is very street friendly and has gone 11.46 at 118, but mostly 11.7-11.9 no prep. The reason for the change is the urge to get the most out of the motor with the last cam change in my life. At 65 yo, I don't know if I will want to do it later.
What considerations are used for your buying decisions regarding cam type first?
My heads and springs will handle the roller pressure. I will be replacing the aluminum rockers with 1.5 RR steel, probably 440 source, Bushed Stainless Adjustable Rocker Arm System - 1.5 Ratio.
Solid, hydraulic, flat tappet or roller? Street friendly, yet fast at the track is my goal.
I will be talking to Dwayne at @PRH this week for his recommendations for specs.
RB 512ci, 440 source stroker kit with lightweight crankshaft, forged pistons, 10.83 CR. Trick Flow 240 heads, 440 source aluminum rockers 1.6RR, Trick flow single-plane intake. Holley Super Sniper EFI, HyperSpark ignition, coil and distributor. TTI 2 inch headers. Hughes 3000 stall TQ(yet stalls at 4500 according to andyF). 727 transmission with transgo TF2 valve body mods. B&M Quicksilver shifter. Gear vendors overdrive to 8 3/4 rear end with 3.91 gears, braced in back. SS leaf springs. Viking dual adjustable shocks. Pypes Exhaust 3" into 2.5 inch. RacePro mufflers. Cooper Cobra 275/60-15 28.2 inch diameter tires, with drag radials for track. Current cam specs 244°/252° @ .050”, 282°/290° adv, .516”/.537” lift (1.5:1 rocker), 112° LSA, .016”/.018” lash, Solid lifter from Oregon Cams.
