Have a 72 duster with 8 3/4 rear , what's the best sway bar recommendations for this car ?
I respect your opinion but I have a front sway bar , and think it would help for the rear , I run 55's on rear , I have front rear sway bars on my ebody and it handles great but if the consensus is not to add I will do more research an may not addnone...put a wider rear tire on it. Put a rear sway bar on an a body and you'll understeer badly...maybe right off the road at highway speeds on tighter curves. Check the tiny sway bars on modern vehicles like big trucks.
surely you mean oversteer correct?none...put a wider rear tire on it. Put a rear sway bar on an a body and you'll understeer badly...maybe right off the road at highway speeds on tighter curves. Check the tiny sway bars on modern vehicles like big trucks.
i would suggest a smaller diameter bar-- something between 1/2~5/8 depending on the rest of the set up.Have a 72 duster with 8 3/4 rear , what's the best sway bar recommendations for this car ?
I did replace the leaf springs with espo springs when I added the 8 3/4 , I like the 5/8 suggestion , might be way to go , I bought a FF steering box stage 3 , will ask them there recommendation as welli would suggest a smaller diameter bar-- something between 1/2~5/8 depending on the rest of the set up.
rear bars can be an excellent addition and great for tuning the suspension package for optimum performance. but like everything too much can be a bad thing in the grand scheme of things.
i don't like bars that mount to the axle, but sometimes that's unavoidable due to limitations of the chassis, exhaust, etc.
that said, if i was buying right now i'd probably hit up firmfeel for a bar.
I have looked at the Bilstein shocks , and may end up buying a set for both my cars , I have them on my truck and they are greatBest investment I've made is Bilstien all around and bigger torsion bars.
And I already had sway bars, QA1, Espo springs.
I ran one, & for a while, w/o the front one......with the over-assisted PS, what fun it was to hang onto...loose as a goose!!! Once I put the 1.125" frt. F-M-J bar I adapted back on with a better mounting system, w/the .870" T-bars, home-stacked 6-leaf rears, & the 3/4" F-M-J rear bar.....that thing stuck like glue. I could run down My neighbor's IROC-Z through the twisties fast enough to ram it & wreck it,..lololol...surely you mean oversteer correct?
also, agree. because of the design of mopar leafs, and the inherently stiff, short front section many cars don't need a rear bar and it could in fact be detrimental to handling depending on the rest of the set up.
The Hellwigs have 3 holes to adjust. They say to use the center hole 1st and adjust. Also links are connected in a better way to the frame.I have front and rear Helwig swaybars on both my cars . Corners like a champ even with little tires . One of the best upgrades I’ve ever made.
It appears that you are sorely mistaken in your understanding of vehicle dynamics.none...put a wider rear tire on it. Put a rear sway bar on an a body and you'll understeer badly...maybe right off the road at highway speeds on tighter curves. Check the tiny sway bars on modern vehicles like big trucks.
340 stock torsion bars and a factory front sway bar I removed from a 73 and installed on my 72 when converting to disk brakes , running 15 inch tires P255 60R on rear P215 65R on frontWhat torsion bars do you have up front? Is it a factory front seat bar or aftermarket? How are you using the car and what tires are you running?
I run front and rear sway bars on my Duster, my rear bar is actually a larger, 7/8” e-body Hellwig.
The important thing is that you’re adding the sway bar to balance the car. The whole deal about A-bodies not needing them is complete garbage, but it does depend on how the car is set up with the rest of the suspension and tires.
Factory cars are all set up to understeer. It’s easier to drive like that and requires less skill. Having a car that’s on the edge of oversteer is faster for handling, but requires more driver skill to manage. If your car understeers, a rear sway bar will improve that. If you’re already into oversteer, well, a rear bar will make that worse.
take this for what it is worth. A leaf spring car does not have a rear sway bar. It is a stabilizer bar.
no quarter is given in the pageant of pedantry.To @OMM’s defense he was talking about the rear “sway” bar. Not the front.
You should do stand up.no quarter is given in the pageant of pedantry.
sorry, i don't make up the rules.
how do you know i don't?You should do stand up.
A face made for radio. I gotta remember that one. lolhow do you know i don't?
i mean, i know i'm funny, but looks aren't everything. you know what they say: a face made for radio, and a voice better for writing...
I am not Ma Mopar
