Jarlaxle
OK, laundry can wait.
Also note that light-duty B-vans with the V6 ran the 32RH (A998) to the end in 2003. Jeep Wranglers and 2.5 Cherokees ran them 80s to 2003-different bellhousing pattern, but the low-geared internals can be swapped into your older case by any good trans rebuilder.
I saw a similar setup on the Power Tour-Magnum swap from a Durango, in a Dart Sport. He relocated the battery to the trunk and mounted the ECM in the old battery location.
I'd go 999. If you find a V6 B-van (any year, mid-80s to 2003!), grab it. That's a lockup 998 with low first gear. If your slant had an automatic, should be 100% plug and play.
This. I have what might be the WORST possible case for a big cam-manual transmission and 2.76 gears. It pulls fine from a stop even on a hill. Cam is a Hughes SER1418ALN10-214/218 degrees at .050", .532/.539" lift, 110 lobe separation, 106 degree centerline. Pulls fine from 1200rpm even in 4th gear.
That's not unusual.
This a pickup engine?
Power steering cooler. If you do a lot of city use (or if you autocross), it helps. Was this from a 2500 or 3500 series pickup, or a 15-pax van? (Wait, truck accessories, so not a van.)
Other than a new oil pump and pickup, I would probably not TOUCH the bottom end. The lowest-budget parts are the ones already there! Plastigage the bearings and send it.
also, are you thinking you want it to be a cruiser? something to get out on the freeway with? if so, you might want to consider a 998 trans (beefy 904). some of the nice things with that are the lower power loss compared to a 727, the 2.74/1.54 first/second gear vs. 2.45/1.45, and you can get them with mechanical/hydraulic lockup (M body) or electric/solenoid driven lockup (IIRC, EFI trucks 87-up). lockup gives you the opportunity to use a higher stall/looser converter without any highway slip. pair that with a 2.76 or 2.94, and it'll still be a hoot around town, but not be cranking 3000+ RPM going down the freeway at 75 MPH. in my 5th avenue I mentioned above, I was actually running a 3.55 rear gear with a 42RH (A500, the 4 speed OD version of an A998). but to do one of those in an A body will require serious transmission tunnel and torsion bar crossmember modifications.
On an episode of Roadkill Garage, they did a 5.9 swap with the factory acc drive into a Duster and had to move (chop up ? , I can't remember) the battery tray and use a small battery to clear the ps pump.
To be honest... not much! This car will mostly be used to bomb around the outer boroughs of NYC. It is a whole 'nother world here. Probably won't see much high-speed use! Or at least, not built with that intention. I do like the 904 recommendation. I also found a 727 lockup trans near me, supposedly NOS from mopar for $850, comes with whole "retrofit kit" including brand new driveshaft, linkage in a box, inspection cover, all brand new from the 80's. But having a lockup trans scares me, I don't know if that a mistake for some reason.
A 5.9l with headers and 4bbl basically makes 300 hp, but if you want a mild cam don't let AJ's made up scenarios stop you from doing it, AJ don't get power is generally added throughout the powerband. Here's a 5.9l with headers and 4bbl, stock cam VS a mild roller comp cam shown on the screen as you can the engine gains from 3,000 rpms+ and no signs of any real loss under 3,000 rpm, so if you want a cam go for it will give you gains you will notice no matter your gearing and stall.
Here's LA low cr 360, with a bunch of mods VS stock 2bbl, headers, mild ported heads, xe250h and xe268h cams 4bbl etc.. Still makes better power everywhere over stock.
Got the heads off today.
The cross hatch is still visible, and no ridge, so I'm thinking I should be able to reuse the bore and pistons if luck prevails.
The amount of sludge in the lifter valley is a little concerning though.
That's not unusual.
Also, does anyone know what that oil cooler is? Is it for the trans? Or the PS system? Or something else?
Sweet. I figured the whole damn way! That's the only way to hot tank it, right?
I'm doing this on a budget, but its important to me to be thorough ... and have nice paint job on the motor. I did a 2k hemi orange paint on a 440 and it was just so damn beautiful. I think this one I'll do in blue.
