Factory Battery
There is an AGM Mopar battery available. Don't know if there is something specific about '73. $3-400 dollars. I have one in my '69, not sure how old it is, but I have had the car for 6 years. It was in it when I bought it.
The batteries like that are junk. They won't last and are insanely expensive (if you can get them, last I knew they were backordered). Most just put them in the car at the show and put them back in the trunk when they leave. I use the battery toppers and a modern Deka group 24 battery.
Example:
https://www.musclecarparts.cc/1966-...rz9swoT-khIYRmch4Q0eRnrpWe5ELWSxoCGxIQAvD_BwE
You can get Red, Green or Yellow caps (cold cranking amps) caps. Have them in all my cars (note Year One make the upper hold down that is just a but wider to accommodate these) and _very_very_ few notice it is just a topper.
Jim
I have had good luck with AGM's, again, mine is 6+ years old, and I drive the car often in season. Having said that, I do have the toppers in two of my cars.
My oldest car one in my Bee (out of 5 total) is now 9+ years old. The one I depend on to start my airplane on backlakes over 80 miles from the closest road was 12 years old this Summer, so I threw a new one in to be safe. Currently using it to run my portable heater. Had it running for almost 9 hours the other day.
Bought the Whole Batt At Speedway Green cap A21 . Witch has the last 2 digits 51 on Build Sheet , and this car is a 1of1 car Don't want to put some plastic top on it
