Blue dot tail lights are illegal on U.S. roads because federal law requires rear lamps to emit red light only. The blue insert alters the color, making light emitted more of a purple and conflicts with lighting reserved for law enforcement.What are the blue dots for, are they a legal requirement?
It's givin the man the finger. There's your simple, non BS unconvoluted answer. Dang John, make it complicated why dontchya? LOLWhat are the blue dots for, are they a legal requirement?
So was mine. Cliff noted. lolI do it well. But it is factual with historical information.
Gotta admit, it looks good. Turned out better than expected.So was mine. Cliff noted. lol
if the whole car's plumbed with flexi lines you will notice a softer pedal. i worked at a rally car supplies shop/warehouse and they discouraged customers from using all stainless braided flexi.Has anyone used or known someone who used stainless steel brake hose with AN-3 fittings in replace of hard lines? If so, how did it turn out? I have a neighbor who says its a bad idea as the hose bulges a little making the brake feel spongy.
Bummer. Its so hard to accept that as some of these lines can sustain 4000 psi as a normal operating level when brake fluid psi is under 1500 psi.if the whole car's plumbed with flexi lines you will notice a softer pedal. i worked at a rally car supplies shop/warehouse and they discouraged customers from using all stainless braided flexi.
neil.
First attempt was a failure. I am trying a new flaring tool by Titan. See how that goes. Bought my flexible tube kit from The Stop Shop. This job will be made worst by not being on a lift. We will see how it goes. Stainless an AN-3 fittings would be so much easier.i've always cut and flared my own hard lines using pipe on a roll. flaring tools that give nice neat flares are pretty cheap these days as are the fittings and pipe.
neil.
My understanding of copper weld thru primer is that it can be welded thru. As mygasser stated, a little more gas may be the issue. The issue I know I have is I work IT as a Server Engineer and am learning to weld. Learning on the front suspension of my car is a very bad idea, and I know it. I was in a jam with someone who has bailed on me several times in the past, and as such I made some practice runs and thought with a change in style, I could be successful. I was wrong, and faced with the very same problem. I will learn to weld, but not on the car suspension.Looks like you have sprayed something on prior to welding? If it is weld through primer pretty sure where your welds are going still needs to be bare metal have you made sure the metal is wire wheeled and clean?
looks like a little more shielding gas may help. welding new clean steel is always easier/neater but get into old bodywork and it's definately 'dirty' in comparison. get it as clean as possible before welding as always.
neil.
Normally, I would just tac things together and pay the pro's to finish. My neighbor seemed to like the working with the primer when he welded the shock hoops. I dont know, like I said I am not a welder and I have not put in the practice to do suspension work, body panels only. I am unemployed, and forced to put the house up for sale mid Jan if I dont find a job. This is making funds tight.Yep i got a fabricator to come to my work to weld things like the chassis connectors as quite dificult as you are welding thick and thin metals together and easy to blow holes etc.
Everyone has a different opinion on the weld through primer as it can make it spatter a bit, some guys will just spray the sandwich part of the metal and leave the weld surface clean. Basically get some tacs on it then wire wheel from where you are placing the welds. Everyone thinks welding is easy until they try it. I can melt stuff together and thats it lol. If i want neat and strong i get my fabricator to do it.
In the states, everyone is crazy to get rich off someones mistake. Such as welding a suspension bracket to the chassis. And it doesnt have to be the car owner. It could be the person who was hit by my car, finds out someone did this work which failed and goes after the person who welded it. And as such, all the mobile welders declined to do the work. Until one guy I called who is a mopar owner said he would drive 3hrs to help me.Sorry to hear mate!! Thats amazing the wife supports your hobby, but also working on cars calms me down. I run a company with high stress and its my destress thing.
Have u had a look on market place even to see if someone will come weld. Its a simple job for a bloke with a portable welder
