amzchad
I heard of using the ford explore rear disc brakes on the rear ends of our mopars
Does anyone know anything about this?
Thanks
chad
Thanks
chad
There is this summit kit SUM-BK1329. And yes I believe you need the green bearings.
Maybe the Jeep 8 1/4 rear disc will bolt on. The difference is the bottom bolt won't bolt up as the Jeep uses the 8 1/4 with 4 bolts, or maybe it could be just drilled out.
I think someone has done this swap on FABO, so hopefuly they will chime in.
I have 96 explorer disk brakes on a 8 3/4 rear end. Unfortunately I don't know the specifics of how it was done as I bought the rear end with the conversion already done.
I got the rear from 446acuda on BBD.
There are some pictures of the brakes and rear here
In them photos they look like Ford housing ends. I could be wrong.
