Where to get throttle cable
superdart
Shade Tree Tinker Gnome.....
DFW, Texas
So...where is the best place to get a replacement throttle cable?
Mine is disintegrating, and starting to bind. Are there any direct replacements out there, or should I go with a Lokar (or other) aftermarket universal?
2 places I can think of, Imperial services, or on Ebay,
http://myworld.ebay.com/ebaymotors/rehrenberg/.
http://www.imperialservices.net/Imperial Services - '60-'72 A-Body Parts.htm
1964-1976 Throttle Cables
These new Throttle Cables are made of premium materials for long life and good looks. Billet stainless ends are fitted to a nylon lined housing, with a stainless steel inner member and clevis. Special lengths and custom ends available by special order.
Throttle Cables
Application
Our Part Number
Replaces OE PN
1964-1966 V-8 IS-511 2465 487
1968-1973 A-Eng IS-531 2899 336
1969-1976 Slant 6 IS-532 2899 335
1971-1976 V8 4Bbl IS-541 3577 523
Throttle Cables are $65 plus shipping
Special Lengths available by special order
Do both the throttle cable and kickdown you will love it...I also went with a cable shiffter.....8)
I also added a spring and bracket at the bottom to make sure the kickdown lever returned....
Nice set-up. I already have the cable shifter and just recieved my cables yesterday. I am going to try to run the same set up you are running. Any words of caution? Has it worked well so far?
Other people have had problems with WOT...on mine I drilled a new hole for the throttle cable on top in the carb cam lever to get WOT...protect your cable for your cable shifter like I did...my exhaust gets close to it....use the spring set up to make sure your kickdown lever returns for sure....8)
