'65 Dart body part interchange questions
Fireball
Auburn, IN
What other years will the fenders interchange with my '65 Dart?
Will all early A body post doors interchange?
Thanks
I think that you are stuck with '65 Dart fenders.
If you can find a '65 Valiant from Canada, then you may get lucky. I'm sure the American Valiants are different.
Probably the same for the doors.
Here's a Canadian Valiant, and a US model.
65 Dart fenders are 1 year only. However; if you use the complete front clip from a 64 or 66 Dart or 64 thru 66 Valiant or Barracuda, that will also bolt right on with all the body lines lining up perfectly. 2 door posts from either Dodge or Plymouth will also work.
Thanks 65 Dartman! I may be able to save my fenders, just an awful lot of pin holes and one broken stud at the rear.
Except for mouldings and trim, the '64 and '65 A-body 2dr sedan doors will interchange and look the same. '63 won't work due to different latch assy's. '66 started the modern lock cylinders so it would look different but should fit OK. You might have to include the hinges as they changed that year also.
