RustyDusty
Rabid Cross-eyed Opossum!
I see most of you are welding these on. If you have the ability to weld, why don't you just fab your own for less than half the price?!
Here are pictures of the door thesholds I purchased from Mister Twister.
Yes they work fine in convertibles, hope this helps DonAny info on frame connectors on convertibles? Doing some reading and see where torque boxes are used...? Will the bolt on type work on a 69 Dart vert?
does the fuel line need to be moved to fit frame ties? mine is in good condition and id rather not mess with it if i dont have to
