Moparcrazy.com
1971 Dodge Dart Swinger BIG BLOCK 4-Speed
You are looking at one of the finest examples of a big block Dart in the country. This 1971 Dodge Dart was located inside an elderly women’s garage in 2007. The time capsule was completely rust free and sported 38,000 miles. The car was taken to the restoration shop where it was completely stripped to bare metal and placed on a rotisserie. It was painted lime green and a new vinyl top was installed. The bumpers were rechromed, the front end was rebuilt, it was fitted with heavy duty springs, drag shocks and disc brakes were installed for maximum stopping power. The rear end was replaced with a completely rebuilt 8 ¾ rear with 355 gears.
Now it was time for the drive line. We wanted big power with street reliability. A 1969 440 Block was used for the professional assembly. The short block consists of a standard crank with eagle rods and diamond pistons with a compression of 10-1. We carefully selected a custom solid camshaft with roller rockers. The heads are close chamber 915 castings with big valves and a race port job. The car breathes through a custom 3” exhaust with turbo mufflers. Lastly, of course we had to install a 4-Speed. A rebuilt Mopar A-833 Manual transmission was fitted in the A-Body. Talk about a scary ride… 11.60 with the street tires spinning all the way down the track.
This vehicle is mechanically sound and can be driven anywhere. All the gauges and lights work as they should. The Dart has big power yet superior street reliability with no disappointments. Everything on the car is new and there is too much to list. If you have been looking for a big block Dart you will not find one nicer. I have collected mopars for many years and promise you this car is set up perfectly. I am available to show this vehicle with ample notice. Please call to schedule an appointment. $24500 pm for phone number http://www.forabodiesonly.com/mopar/announcement.php?f=41&a=6
