Wanted, Vertical gate shifter
NITROTRIP
DIXON NEW MEXICO
Rating - 0%
0   0   0
Good evening all,
I am looking for a inline- V- or vertical gate shifter.
Mr Gasket or Hurst, I think they are the same, just
different name on the stick. If missing rods and plates,
it is not a big deal. I am able to make the shifter
mounting plate. I am starting to build a 512" 4-speed
69 dart. I have an original 340 4-speed 69 dart also.
It has a straight short stick/ very short throw very
narrow gate Mr Gasket shifter in it. 1 1/4" from N into gear.
Shorter than the Hurst comp plus my brother had in his.
But that one is the only one of those I have seen ever.
Stick is same length as a V-gate. So another one like
that would work fine also. Or a reverse lockout comp plus 3 as
a second choice. I am a machinist so rods and plates/heat
treating is no big deal.
I just found this forum and you all are first class.
Take care,
Rick
i have one...good shape...but no rods... make an offer..
I have one also.......got it on trade. pm me if you are still after one.
Andrew/kidd
Kidd / dust-u,
My brother just found me a new old stock one, So I think I am set.
When I get it I will look it over. If it is OK them I am set, if not I will get
back to you.
Thanks All,
Rick
