'62 valiant wheels
gsoco
gsoco
Mount Pleasant, SC
Rating - 0%
0   0   0
Can anyone tell me what custom wheels will fit for a '62 Valiant? I am trying to buy online and most sites don't go back that far. Are they the same as a '67 cuda?
First you'll have to know your bolt pattern size. 5 lugs on a 4 inch circle is most likely what you have.
Sumitt racing is preety good with the tech on stuff like this.
67 barracuda had the small bolt hole pattern 5 lugs on a 4'' pattern, If you have 5 lugs , yes they are the same, Just make it clear you have the small bolt hole 5 on 4''
I used the SBP Rallies on my 66 and they should be the same if you have 5 lugs :happy10:
american racing outlaw II 's are available as well as an "ansen" copy wheels too from this company 5x4 bolt pattern
