Engine yes, trans maybe. They used 2 styles of transmissions in motor homes. One style is just like a car and the other uses a real short tail shaft with a big parking brake assy. on the back. To change the latter to a car style trans. means completely disassembling the trans. to replace the output shaft cause the output shaft goes in from the front.
