Can Someone That Has This Set Up Give Me The Correct Width Of The Bars, Mine Are 47-1/4 Inches, Does Not Seem To Fit. I Did Do Some Research On Here And Apparently Some Have Too Much Of A Kick.
Mine measures 46-3/4 over-all, and about 44-7/8 hole-to-hole.
You need to use their hardware on the ends, which mounts the end link to the shock bolt, not the factory sway bar tabs. The Addco bar will be below the shock bolt. It might be possible to use factory tabs, don't know.
Make some better brackets to mount the bar to the k member. The Addco pieces are not good - mounted with one bolt.
Yeah, no such luck with mine either. Flipped that damn thing over and either way, the ends are about 2 inches too wide......wonder WTF is up with these - guess it goes in the box and back to summit.
