Ajp440
I recently picked up an early ford Dana 60 from a 1964 ford f100 the specs as far as dimensions go drum to drum measurements are identical to Mopar b body Dana 60, the only difference is the perches and the Lug pattern it ls 5x5.5. Has anyone ever used these danas without narrowing them and keeping the big five lug patter? It is a powerlock rear with 3.54 gears. Thanks!!
