Been working on the disassembly phase of the project but had to rent a storage space to store parts since this is being done in a regular sized 2 car garage. I have removed:
engine and transmission; Front End with K-frame; Interior
Once the carpet was removed, it exposed the bad floor pans bu the good news its only the front left and right sides not the complete pan. After removing a bunch of spare parts from the trunk, that exposed to attempted repair of the trunk floor which will need to be replaced but the trunk extensions are good.
The paint is being removed using Aircraft stripper and scraper. The orginial car color was black with red primer and the car was oversprayed using gray primer and white paint and lots of Bondo so stripper has to work double duty.
I've modified the steering column for floor shift and had to modify the lower column support to accept a different bearing since I could not find a replacement.
