340_833 dart
1973 Dodge Dart Sport 340
Rare factory 340, sunroof car
Engine specs;
340 bored 0.040, KB hypereutectic pistons, CR approximately 9.8:1.
Block was decked and squared. Entire rotating assembly was balanced. Clevite main and rod bearings. ARP bolts are used on the rods and main bearings.
Double roller timing chain set with Mopar Performance chain tensioner.
Factory cast iron O heads with 2.02/1.60 stainless valves. Chrome-moly retainers.
Lunati Voodoo #60403 cam with .498/.513 lift and 228*/234* duration @ 0.050.
Lunati dual valve springs. Teflon valve seals. Bronze valve guides. Intake ports are gasket matched. Three angle valve job and hardened exhaust seats. Crane ductile iron adjustable rocker arms on chrome rocker shafts.
Edelbrock Performer RPM intake manifold with a Holley 750 cfm, vacuum secondary, carburetor. Mopar Performance distributor.
Complete ACCEL 300+ ignition system.
TTI headers feeding into 2.5 exhaust pipes.
Approximately 7000 miles on the 2002 rebuild.
3-core 26 copper/brass factory style radiator with twin 2-speed electric fans.
Drivetrain & suspension specs;
Chrysler 727 transmission, rebuilt in late 2009 with A&A Transmission components and a Trans-Go TF-2 shift kit. Mopar Performance deep-sump transmission pan. B&M flexplate. PTC 2800 rpm torque converter. Hurst Quarter-Stick shifter.
Chrysler 8.25 rear axle with 3.91 Mopar Performance gears and Trac-Lok differential.
Four wheel manual disc brakes.
.890 diameter torsion bars.
205/70 front tires on 14 x 7 Cragar SS wheels.
255/60 rear tires on 15 x 8 Cragar SS wheels.
Entire front suspension was rebuilt with MOOG parts.
ESPO +1 rear leaf springs and new bushings.
Body specs;
Viper Red base coat/clear coat Standox paint.
Welded in subframe connectors.
New carpeting.
New upholstery on the inside panels.
New upholstery on the front and rear seats.
Modern, 3-point front seat belts.
Custom built dash/instrument panel with AutoMeter and AutoGage gauges.
Battery mounted in trunk.
The factory underhood wiring harness was recently replaced with all new wires and WeatherPack connectors.
New windshield.
The entire heater assembly and hoses were removed.
Notes;
There are extras too numerous to mention. Plus, I have a lot of spare parts that will go with the car.
Asking price; $18,500
Cash or bank wire transfers are the only payment methods accepted.
Title is clear and will be transferred as soon as the full payment is received.
Please contact me either through PM here or at 73dartforsale at att dot net
Plenty more pictures available upon request.
Serious inquiries only.
Please, no tire kickers.
No third party dealers or brokers.
Car is sold as is. No warranty and/or guarantee is expressed or implied.
Buyer is responsible for any applicable taxes and/or fees.
Buyer is responsible for transportation of the car.
Thanks FABO.
http://i45.photobucket.com/albums/f60/340727dart/Dart for sale/Passengerside.jpg
http://i45.photobucket.com/albums/f60/340727dart/Dart for sale/Driverside.jpg
http://i45.photobucket.com/albums/f60/340727dart/Dart for sale/Interior.jpg
Engine specs;
Body specs;
New carpeting.
New windshield.
Notes;
Thanks FABO.
