69 barracuda fastback
cuda69340
member
upper chichester, Pa
Rating - 0%
0   0   0
1969 barracuda fastback formula s. 340 .040" over w-2 heads. 13.2:1 comp, .600" solid cam, 1.7 roller rockers,milodon,headman jet-coated tubes,csr waterpump,msd 7al-2 ignition, flex-lite fans, runs-sounds stout,jw bellhousing, powerglide trans w/trans brake,8 3/4 rear w/spool, strange axles, s/s springs w/adj. Snubber.6 pt. Cage,nos complete front form s grills w/turn signals,nos form s tail panel, mr g's redone instrument panel,k-member replaced with alterkations coil over, rack & pinion, tube a-arms, wilwood disc brakes, fuel cell,battery in trunk,painless wiring harness & control panel,fiberglass fenders, hood, trunk,aluma-star wheels
body is solid,garage kept since new, needs body work on enlarged wheelwells, paint and assembly, never raced, delivery can be arraigned where possible. $13,000 obo
1969 barracuda fastback formula s. 340 .040" over w-2 heads. 13.2:1 comp, .600" solid cam, 1.7 roller rockers,milodon,headman jet-coated tubes,csr waterpump,msd 7al-2 ignition, flex-lite fans, runs-sounds stout,jw bellhousing, powerglide trans w/trans brake,8 3/4 rear w/spool, strange axles, s/s springs w/adj. Snubber.6 pt. Cage,nos complete front form s grills w/turn signals,nos form s tail panel, mr g's redone instrument panel,k-member replaced with altekations coil over, rack & pinion, tube a-arms, wilwood disc brakes, fuel cell,battery in trunk,painless wiring harness & control panel,fiberglass fenders, hood, trunk,aluma-star wheels
Please read rules in place...http://www.forabodiesonly.com/mopar/announcement.php?f=41&a=6
Price is ?????
im really intrested in the car, could you send me more pics of the car, engine interior, underneath, an also how many miles on the motor? is it running?? thanks Brett,
are you intrested in any trades?
