need air cleaner help.
racerx23
Returning my 72 340 Demon to stock and I was wondering if anyone had info and or pictures of the air cleaner. Where vaccum lines go, is there some kind of heat shield to connect exhaust to air cleaner, and if so where can I get one,and so on. Thanks any help would be greatly appreciated. Bob
thanks for the links you wouldn't happen to know if they still make the stove for the exhaust or where i might get one?
I'm sure I've got a spare heat stove in the garage. Let me know if you're still in the market and I'll check.
I've also got two '72 trap door air cleaners left if you're looking to buy.
i can use the heat stove how much do u want for it, and i already bought an air cleaner from u. i can use the breather if u have one and i'm open to suggestions on what else i may need to complete this install. bob
I'll see if I can dig one out after work tonight and post some pics. I probably have the mounting hardware as well. Stay tuned.
I have a heat stove off a 70 318.
Not sure if it is the same as the 340.
Maybe Dusteriffic can help with some measurements.
Here is a pic of it, with a bunch of other parts.
