I have a 74 dart 3 on tree manual with a slant six..I have been told it can bolt directly to a 318 with no problem? is this true or am I hearing stories? How much HP/torque can this trany handle. It is fun to drive dont want to swap it out.
hell, aren't they the same as the ones they raced in the Max Wedge cars?To answer your strength question they put those 3 speeds as standard equipment behind 340s and 383s.
Bell housing and Z-bar will be different. Not sure about the 3 on the tree linkage tho. To answer your strength question they put those 3 speeds as standard equipment behind 340s and 383s.
IMO those 903 transmissions are a POS. If you just putt around with it, it'll work but they won't handle any kind of horsepower. The 230 is a much better 3 speed but it was made for a floor shift car. I'm not sure what you'd need to do to get it to work with your column shift linkage. The 250 3 speed is also better than the 903 but not better than the 230 but at least it was designed for column shift vehicles. The 745 is a pretty good one too but they are not too easy to find anymore.
The 4 speed conversion isn't much easier but it's a nice strong transmission. If you plan on keeping the column shift, like you originally stated, a 4 speed would be a real interesting project! Modify an old Mercedes column maybe?
