Someone can probably get you in the ballpark, but because of differences in assembly from car to car, it would be better for YOU if you learned how and measured it yourself. Because one person's results may well differ from yours. It's always best in this situation to get the exact measured results from your own car to determine exactly how much room is there. Here is another good site that explains it a bit more:
What are you trying to put wheels on? I can help. Do it everyday. What brand of wheel are you looking at buying. Off the shelf wheels only come in a a couple differant B/S. a custom wheel can be set to your needs.
Tim
