Ok so I have a 70 dart 318 car.It has the trim down the side above the wheelwells and a stip below the door. so my question is should I put the trim back on or leave it.If I leave it off I'm going to add a black stipe across the trunk and down the quarters.I'm not sure the stripe and trim would look good together.If I delete the trim whats the best way to plug the holes so I can put them back on later if I chose to.I figure welding is the best way but redrilling welded holes is tricky.I would prefer a muscle look over a classy look my opinion.Please be honest.I'm going back with the hemi orange and I will probably use the trim under the doors.Thanks in advance.
Oh and the top will be orange also and maybe two black scoops on the hood.
