car #2 71 340 auto numbers matching partout wedge car!
340plot
the bushy bush
va
Rating - 95.8%
23   1   0
i know, i know, i should not part it, but i must finish my pink car, and the way the economy is, it leaves me no choice.
this is a real wedge car, but cannot be proven, as it has no fender tag or build sheet
car is solod. does need some work. trunk needs tire area. someone put floorpans in the rear floors, but did not do a good job. driver front floor has a 3x3 inch hole, but solid otherwise. i would not replace that floor, just a good patch would be great!
roof is solid, doors are solid. all glass is good, and i have another windsheid for it. the dash itself is still in the car, but no longer has the rallye harness, or guages.
i have year correct seats for it, but need to be redone.
has 8.75 with 3:91 suregrip chunk
i have the origional number matching 340 for the car. it is apart, the block has been dipped, and checked for cracks. it is still standard bore. i do not have the factory rods or pistons for it. p.o could not find them.
also have a set of j-heads (2:02). they will need to be freshened up. i do have the 71 340 trans, but no sure if it is numbers correct
the front frame rails had caps put on up front. could use new inner fenderwells. looks like it was cut for headers out them, but the nomeone tacked in pieces over them to fill it. rockers are solid, needs lower quarter metal.
i have the sharktooth grille also for this car.
i am posting this for sale as in any type of package you may want.... whole, minus either this part or that, or just plain ol partout!
i want 3400.00 for the car the way it sits.... firm
i will have title by febuary .
but this is a partou. first come, first serve.
car and parts located 30 minuted from martinsville international speedway in va
will also take 70 duster 340 parts in on trade, like 4 speed carpet, nice door panels, trim,rims, bumpers.........
here is the deal. i could of got the title in hand, as i looked at it to make sure it matched the car. however, the p.o has signed it over to the garage i bought it from. therefore, i did not want to take it with me being the third sign over, that doen not work in va, so, he owns a full legit business, but is only allowed to transfer a certain amount of titles per year. so. he is going to send it in the first week of january, andi figured it would take no more than a month for it to go into his name, they send it to him, and him send it to me.
i can just get that tile from him, but his garage name is on it as the buyer.
hope you understand!.lol
about keeping it till after the pink one is done..... i would love to do that, but the economy will not allow that to happen at this time!
how much for hood pin setup, sharktooth grill, air cleaner if you have it, fan/shroud/radiator? PM me with individual prices thanks for your time, -Dan
Wow, you are a walking soap opera with these 340 cars eh plot?
I can't wait to see what happens next.......
