MY340
Original AZ 6 cyl/3spd car. Still has clutch pedal on the firewall. Older repaint/drive quality of factory FE5 Rallye Red with chips, cracks, scratches. Pretty much rust free straight body. Good black interior with padded race buckets, new carpet, upper door seals, cat whiskers and rear package tray. Electrical system original but almost everything works except horn, doom and backup lights.
Less than 5,*** miles on rebuilt 365hp PAW 360 .030 over shortblock with 9.1 comp, rebuilt 1.88/1.60 heads, 280/480 Comp Cam, Weiand Stealth hi-rise, 1" 4-hole spacer and manual choke Edlebrock 750cfm carb. Hooker headers with full dual exhaust and chrome tips. Runs strong! Have receipts for engine/tranny rebuild and most other newer parts on the car.
Rebuilt 904 transmission/shift kit and Hughes 2600 torque convertor, 8-3/4" rearend & 3.91 gears with Powertrax locker. Newer suspension, new rear leaf springs, newer brake system with manual Kelsey Hayes four piston setup. Subframe connectors. Small bolt pattern Rallye wheels with BFG T/A's 215/70R14's & 245/60R14's
Price is $7200 or best offer and car is located in Washington, Mo.
