75gold.uster
does anyone know if sbp (5 lug 4B.P.) spacers exist? and if so where i can get them or if anyones has some they would be willing to sell! thanks alot!, andrew
how far do you want to move them out? We hav a indexer for our mill and can make them. What thickness and aluminum or steel ?[/QUOTe
whatever metal will cost me less , i will find out how thick i need them thursday so i will let yopu know then! talk to you then!
i have two adapters but not spacers, they are 4" to 4.5" , 1" thick
you could, but i wouldnt advise it
when I needed a set...I couldnt find them...I had a set made
any idea how much a set 1/8" thick (or even 1/16 if possible-aluminum would be fine) would cost? I have the odd rub at lock on the fronts and have thought about bringing them out a little to eliminate it.how far do you want to move them out? We hav a indexer for our mill and can make them. What thickness and aluminum or steel ?
