JefftheComputerMan
ok i finally got the drums off the front after removing the entire spindle on drivers side. Pass side did not require this...which is correct? Are the bolts supposed to stay on the drum or not ( See pics)
At this junction I have a better question, Can I replace the drum and (whatever thats called that has the bolts on it) with a 5X4.5" pattern to get me away from the 5X4 that is original?
