TTI header ground clearance
joes68340s
Rescue CA.
Has anyone with tti headers autocrossed or run there car on an open track. I am curious about ground clearance. I am working on a 1968 Barracuda. Thanks
small block?? if so the pitman arm hangs lower then the headder.
let me see if i can find a picture for ya.
Just measured and on an A body they ae only about 1" lower than the front frame rails under the front doors.
Maybe the later cars are lower, but the early ones are just fin!
here ya go... this is when i first put the tti headders on. look how high they tuck up there...
another added bonus. look how out in the open the plugs are... gotta love that..
even on my early abody they tuck in nicely. but the clearances are really tight and autocross could be problematic since the torsion bar threads though the header. Not really an issue for you i guess
