[SOLD] 1964 413 for sale
Hadahemi
Illinois
1964 413, top pad reads V41, maltese cross, 7, 15. Casting date is 4-4-63, casting number is 2205697-4. AAQA block. I don't know the cylinder measurement, but a ridge has been removed. Heads are 516's. Pistons and crank are in fair condition, may or may not be able to be reused. Everything in the pic is included: block, crank, pistons and rods, timing cover, heads, valve covers. If I can locate the following items they will be included as well: original 4 barrel intake, water pump housing, harmonic damper. Located in Annawan, Il. no shipping, $300 obo.
