moparwedden
I Have my 8 3/4 in the machine shop to get shortened, he needs the sure grip out to run a bar threw to keep it true, how hard is it to take out, never had one out before.
You shouldn't need to disassemble the center chunk. As said above, just remove axles, then diff from front.
I disagree if the shop is using this method.. They will clamp bushings in the main caps in the center section and bolt it in place. Next they will slide a steel shaft through the diff, and then they will use bushings on the ends. This will ensure everything is lined up properly before welding it together.
You might give them a call to confirm this is how they are doing it.
You beat me to it lol.
I did not even think about using bushings in the carrier bearings instead of using the center section bearings. This makes sense, though the center section could be off by a little bit (differing from the bushing used during the process you showed) and lead to the parasitic losses I mentioned.
However, there's not too much that you can do to avoid that. These things were assembled very precisely the first time around.
