kjelledart
a running eddy 650 on my 318 i have 350 hp work great wery god trottle response
yes ignition problems can be mistaken for carb problems
why a spare carb is nice to have, if the problem is the same, its not the carb
Please let me know! Thanks.Well bought molley 750 , but switching on Monday to a 670 street avenger Holley . The Carter AVS I had would bog off the line , and it had been rebuilt and set up a few times . By Tuesday I'll let you know how it goes . Basically I have the same set up , 340 40 over , 10.5:1 forged pistons 274 comp cam , mild port on the heads and air gap intake .
Yes we have tried everything , giving up on it , will keep it on the numbers matching block sitting in my garage . I built the motor in it now to beat at the track , guess a 42 year old carb just does not cut it . Most here say holley is going to work best on the track so I.m going for it .Did anyone ever try the air valve adjustment on it? I have ran quite a few AVS carbs in different applications and never had any bog issues as long as the secondary air valve was adjusted correctly.
http://www.summitracing.com/parts/HLY-0-80670
I'm going with the non ultra 670 . Is it worth it going ultra
* Did you get to the track?Wow !! Holley is on , car runs smoother , starts faster , een starts in the cold . Electric choke works well , very well . So far great punch off the line , seems better all around , from start to top end . Hope the track is open this week so I can get a test run with no bog Cater on the car . Hilley started right up out of the box , just had to adjust choke and idle , other than that it runs great !
