Frame connectors and Leaf Relocator
Cazbah362
Nevada
For the best product, price etc. Who would you use for Frame Connectors and Leaf Spring reloctaor kits for a 71 Dart Swinger?
Don't know about relocation kit.
For frame connectors cheap is make them yourself out of 2x3 1/8" thick steel tube. For an exceptional quality design of subframe connector for more dollars get the ones from www.uscartool.com
Same goes for the re-locators, weld it up!!! Save a buttload!!!
If I was going to do it all over again, I would have made the frame connector and the spring relocation box one continuous piece of steel. Yes, you would have had to cut the floor so the piece of steel would have fit, but it seems to me this set up would be stronger.
I saw someone do this on his early 70's dart, and I really liked how it turned out.
I hope this helps.
Thanks,
OldMoparsRule!
We carry the frame connectors and the leaf spring relocation kit. We ship with in the US for FREE and you can use your member discount.
Forum Member Discount 10% off over a $200
James From
PST Marketing
1-800-247-2288
Ext 316
jfrom@p-s-t.com
