I wanna know, where do you find those heavy negative battery cables with the "cast copper" ends. those things are neat. I want some...
here is the info i copied and pasted from the summit racing web site. they are super easy to use and you never have to worry about a crimp coming loose or buying an expensive crimping tool.
Manufacturer's Part Number:1852
Part Type:Battery Terminals
Product Line:ACCEL Battery Cable Terminals
Summit Racing Part Number:ACC-1852
Battery Cable Terminal Style:Eyelet
Battery Terminal Size:3/8 in.
Battery Terminal Material:Lead
Battery Cable Terminal Gauge:1-1/0 gauge
Quantity:Sold as a set of 4.
These ACCEL battery cable terminals feature an easy-to-use compression fitting--simply twist and turn them on to the ACCEL Lightning cables. They are available in 1/0-gauge, 2-gauge, and 4-gauge sizes, so we have every possible configuration covered. Made from heavy-duty lead, these ACCEL battery cable terminals will maintain high conductivity to and from your battery.
Warranty
Manufacturer's Part Number:1860
Summit Racing Part Number:ACC-1860
ost
Battery Terminal Material:Copper
Quantity:Sold as a pair.
