JOES4FORTY
Active Member
I have the following big block A-body parts to trade; I'm interested in a 340. I am in Texas.
68-69 Dart/Barracuda big block k frame
383 drivers side motor mount, bolts and insulator
440 drivers side motor mount repop
ten inch front brake set up both sides, spindles, shoes, drums etc.
Upper control arms both sides with cam bolts Lower control arms with sway bar tabs both sides
699 big block oil pan with idler arm notch and pick up tube
Pair of strut rods with nuts n bolts
Used tie rods both sides
Small block idler arm
