straightlinespeed
Sometimes I pretend to be normal
This is mounted on the fire wall in the cowl duct. The wire harness was not hooked up and what appears to be a vacuum line fitting had no hose connected to it. So what is it? Is it necessary or can I fill the hole that is in the cowl when I remove it?
